Question about Drills
I need a 16mm chuck key with a pilot (7.5mm approx.) for a CYC chuck for an industrial floor drill press variable speed. I would like to get a general repair manual if possible. Bob
rowdy45176
  • 2176 Answers
SOURCE: how to remove chuck from drill press
I just looked at a breakdown for this tool and it is not that clear. But to get an owners manual you can go to Searspartsdirect.com and type in your model number and look at the same schematici I did and also order a manual for about 7.50. Usually though on a drill press like that it would be a morse taper. Do you see a slot cut thru the spindle on both sides, if so there should be a tapered key that came with the unit. In that case what you would need to do it put the key in the slot and tap it with a hammer to remove the adaptor and chuck. Let me know if I can help further
Posted on Jan 03, 2009
  • 10865 Answers
SOURCE: Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Posted on Feb 08, 2009
efs_perpends
  • 1996 Answers
SOURCE: Parts and manuals
You can download a .pdf copy of the manual for your drill press by clicking here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 08, 2009
cojon
  • 7 Answers
SOURCE: Chuck keeps falling off drill press
While roughing up with sandpaper might work, but the usual problem that causes a chuck to fall off is a mismatched taper or either the chuck or the spindle has a dirty surface. The tiniest bloom of rust will cause this. Additionally a mismatch of depth will also cause a poor fit. To fit correctly the taper must be correct on both parts and they need to be clean and lightly oiled.
If it is necessary to san these pieces, use a very fine wet or dry paper. I would not use paper beyond 320 and use a light oil such as kerosene or diesel oil rather than water. Check the dept by looking inside at the wear marks. If the inside of the chuck receiver shows wear so close to the bottom that you cannot ascertain any distance between the wear marks and the bottom, the chuck may be bottoming instead of tightening on the taper correctly. You can easily check it with some fine shim material or perhaps three to five thickness of aluminum foil. Cut five thicknesses to fit in the bottom of the chuck (not all chucks have actual bottoms and go clear through) but not on the walls that are tapered. Reinstall, and remove. Is the aluminum foil damaged/show contact marks? If so, did the chuck go on all the way and come off more easily? If so, the problem is bottoming. Bottoming is quite rare but can happen when different than spec chucks are used.
You might also examine the surfaces of both. They should look pristine with no scratches and marks. If not, that could also be the problem. A correct taper fit is difficult to spin, or remove during normal drilling operations.
Posted on Jan 04, 2010
al_kupchella
  • 843 Answers
SOURCE: i need a chuck wrench/tool for a duracraft drill press
Are you talking about the chuck key? That's the little wrench with a collar of gear teeth on it.
There are only a few standard sizes plus a couple of odd-balls. Last time I looked, Sears carried a good selection. If you have the old one, take it with you to the store. If you don't have the old one, find a way to measure or approximately measure what you need. Another chuck key that doesn't fit can be a useful reference. If you can find something (maybe a drill bit) that is a close fit into one of the three holes in the chuck, that can be useful too.
Posted on Jan 19, 2010
I need a manual for the 5 speed DP MINI 1/3 hp 1/2in chuck. I really need the assembly manual. Can u help me find this
Northern Industrial Tools Benchtop Mini Drill Press - 5 ...
www.amazon.com > ... > Stationary Drill Presses
Amazon.com, Inc.Northern Industrial Tools Benchtop Mini Drill Press - 5 Speed, 1/3 HP - Power ... Yes the directions are bad as other reviews have said, but 3 bolts 3 screws and ...
Oct 15, 2015 | Drills
How to insert bit for Black and Decker 3/8 Variable Speed Reversing Drill.
Most new cordless drills don't have a key(keyless chuck). Put the drill in reverse and hold tight to the chuck barrel, pull trigger and the chuck will open. Opposite to close/tighten Best I can do with info provided
Apr 15, 2015 | Speed Drills
Alternative chuck key specifications
Delta is always creat problem.
If you want to find best drill press open the link Black Bull 16 Speed Drill Press Explained
Jan 17, 2013 | Drills
I have a model 1689 drill press with a 33 taper jacobs chuck I need to remove the chuck to put a larger chuck on is the smaller chuck threaded on and if it is, is it RH or LH thread and how do you hold the...
you dont hold it, the chuck is a taper fit and you would need wedges to remove it. the newer chuck would also have to have the same taper to work. if replacing the new chuck you would need to make sure the parts are clean, use a brake cleaner and a paper towel to clean them and then they would press together. Let me know if you still need more assistance.
Jan 13, 2010 | Speed Clausing 15" Variable Floor Model...
How do you remove the bit
hold on to the key less chuck and put the drill in reverse. if the chuck doesn't release the bit hold on the top collar and twist the chuck
Dec 06, 2009 | Ryobi 18v Variable Speed Right Angle Drill...
How do I remove and replace the keyless chuck on a makita hp1621F?
Remove the screw inside (clockwise)
mount a big Allen key in the chuck ,shortest part inside the chuck,
hurt the key with a hammer to make tre drill move counterclockwiseto unblock it
Nov 16, 2009 | Makita HP1621FK 5/8" Hammer Drill, 5.7...
Need a chuck for this drill
what is the chuck mounting size or taper? It should be stamped in the chuck itself, let me know what you find and what area you are in city, state and zip and I will try and find one near you.
Oct 09, 2009 | Wilton 2223VS 20 Inch Variable Speed Drill...
PRO- TECH DRILL PRESS BENCH MODEL
parts can be found on amazon, take a look here: Amazon com Drill Press parts. I hope this was helpful. Cheers
Jul 19, 2009 | Delta 15 331 15" 115/230V Variable Speed...
Drills Logo
395 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
