Question about Garden
What is the propper way to reseal a wood patio deck
  • 3,287 Answers
Check the deck by dripping some water on it. Does the deck absorb the water or does it bead up and roll away? If it beads up, it would be a waste to reseal, as the old seal is still doing its job.
I start by thoroughly washing and clean the deck surfaces with a pressure washer. Use a wide spray pattern nozzle (not the needle stream pattern), keep the pressure down and the tip away from the surface. Pressure washers can create pressurized streams of water that can literally bore holes in your deck material if you're not careful or not paying attention. Spot remove mold and mildew with a 50/50 mixture of water & bleach and rinse thoroughly. Clean and rinse other stains with products designed for this use by hand as needed.
Allow the deck to dry completely. If you used a pressure washer - it will require longer time than normal to dry. Some sealants allow for sealing before drying (but I don't know how well they work).
Purchase a quality sealant - such as Thompson's Water Seal (there are others, too). Read and apply as per the directions. Ask the sales people if you have questions about applicators and coverage based of the size of the container. Some sealers recommend the use of a roller or an air pressurized sprayer and wand to apply two thin coats of sealer - rather than a single heavy coat. Both methods have their good points and bad - so neither is better of worse than the other really. You could alternate methods each time you apply sealant to get the best protection. The spray method is faster - but results in much more waste. The spray also gets to the sides of the deck boards rather than just sitting on the top surfaces. Don't forget to apply to the ends of boards wherever exposed, railings, balusters, stair risers and any other untreated wood exposed to weather.
I hope this helps & good luck! Please rate my reply. Thank you.
Posted on Apr 05, 2011
What would be the best way to fix a metal plate or trim on the outside of a wooden patio door?
2 part epoxys work very well . it will say wood metal plastic and bonds in around 5 minutes.
Apr 17, 2016 | Cars & Trucks
Tip
How To Re-Wax a Wood Deck for a Trotter Treadmill
Following are instructions on how to re-wax a wood deck for a Trotter treadmill and a list of materials needed for this procedure
Materials Needed for Re-Wax
  • 1 lb. of Trotter deck wax
  • Clothes iron (never to be used on clothing again)
  • Belt sander with 120 grit sanding belt
  • Vibrating sander with 250 and 400 grit paper
Pre-Existing condition: If your wood Trotter treadmill deck is worn down through the first ply, it cannot be re-waxed.
  1. Using a belt sander and 120-grit belt, gently sand in the same direction as the grain the glazed layer off the top of the deck until you have reached porous wood. If, while sanding, the first layer of ply has been sanded off, the deck can no longer be re-waxed
  2. Using a vibrating sander with 250-grit paper, sand the entire top surface of the deck until it is smooth and soft.
  3. After sanding with the 250-grit paper, continue sanding with 400-grit paper until completely smooth.
  4. Heat the clothes iron to its maximum temperature. Put a handful of Trotter deck wax on the center surface of the deck and place the preheated iron on top of it until the wax melts.
  5. Work the wax into the deck surface by pushing the melted wax across the deck with the iron. Add more wax as needed until the entire top surface of the deck is impregnated with wax.
  6. Apply just enough wax until the wood is saturated with wax.
Do NOT leave wax pooling on the surface of the deck.
How To Re Wax Wood Trotter Treadmill Deck
on Mar 11, 2015 | Exercise & Fitness
We were given an 87" stainless steel propane patio heater. Our deck ceiling is 96". Will that be enough clearance?
Had a look at the manual on a BFX750 patio heater and the distance required is 50cm above (18") and 60cm to the side (24"). If its the same type with around 13kw or 44,000BTU/h of power then this is the clearance is needed for air and heat.
Dec 31, 2012 | Stainless Garden Sun Steel Propane Patio...
Building a suncast shed on 10 x10 patio block
IF you're speaking of the hard black plastic floors that come with thes, I'd put it directly on the patio stones. No wood to rot.
Jul 13, 2010 | Suncast 10' X 10' Storage Building
When you engage the mower deck the mower will die and as long as you don't engage the mower deck it will not die.
Check the seat switch for propper connection and position. Also, check any wiring that may be attached to the mower deck. In an extreme case, the pto switch or foot pedal switch may be defective, but mostly unlikely.
Nov 23, 2009 | Garden
Main Heater will not light off
turn the gas on real slow. The air in the line is blowing out the pilot
Aug 26, 2009 | Stainless Patio Heaters - Steel Deluxe...
Motorised Face won't go back up propperly
I recently bought a non working Pioneer DEH-P6850MP off Ebay and found that the ribbon between the face and deck was the problem .When the ribbon was given a bit of a wriggle the deck would fire up and the face would go back in .Dont know if this helps but i didnt see any other helpful hints anywhere ?
May 23, 2009 | Pioneer Car Audio & Video
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
