Question about Acer Computers & Internet
When using my touch pad on my Acer Aspire laptop, i can usually just tap it to click on icons. But i accidentally changed some settings which means I have to click the touch pad button in order to click on icons. How can I find the settings to change it back to how it was before?
  • 57 Answers
I dont know for sure if it is here, but look in the mouse settings in the control panel
Posted on Aug 06, 2008
How do I fix my acer aspire touch pad?
some touch pads have a tap to turn off, and a double tap to turn back on... also check you F keys.
Jun 03, 2014 | Acer Aspire Computers & Internet
Cursor jumps into a previously-typed word or line and emails won't open
which email account ??
Acer laptop computers come with built-in touchpads to control cursor movement onscreen. Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that Acer includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Click on the Start menu and open the Control Panel. Choose an "Icon View" option from the "View by" dropdown menu, then click the "Mouse" icon. Navigate to the "Device Settings" tab and click on the Synaptics device in the list. If you have installed and use custom software other than a Synaptics application for controlling the touchpad, select it instead. Click the "Settings" button. Click the "+" symbol to expand the "Pointing" section in the left frame, and then the "Sensitivity" section. Click on "PalmCheck." If you have replaced the Synaptics drivers, the menu may use a different set of options. Click and drag the bar to the right, closer to the "Maximum" setting. An increased PalmCheck setting will help decrease cursor jumping due to accidental palm activations, a common occurrence when typing. Click on "Touch Sensitivity." Click and drag the bar to the right, closer to the "Heavy Touch" end. This will ensure light brushes by fingers or accidental activations by other objects will not cause the cursor to jump. Click "Apply" to test the settings, and "OK" when satisfied to save the changes and close the window.
Try right clicking on email select open
Jan 28, 2013 | Acer Aspire One PC Notebook
Jumping cursor while typing
You can try following step:
  • Double click on touch pad icon in your system tray. click on "Pointer Options".
  • Then click on "Advanced" tab in left upper corner.
  • Click on Advanced Feature setting. Click on "Settings" in Pointer speed and tapping setting box. Uncheck "Enable Tap" box.
  • Click Apply.
Aug 30, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
Acer aspire 5517 touch pad not working.
Also on this laptop you can hit Fn+F6 to enable or disable the touchpad as well there should be a touchpad disable button to the right of the power button that can be very easy to accidentally press.
Mar 15, 2010 | Acer Aspire 5315 Notebook
Mouse touch-pad
Click Start > Control Panel > Mouse > Device Settings (tab) > Settings (right hand side, immediately under the white box with your touch pad device listed)
Select "Tapping" on the left and make sure it is enabled.
If tapping was enabled, go to "Sensitivity" on the left and adjust the touch settings.
Thanks for using the FixYa forums!
Mar 31, 2009 | Acer Aspire One PC Notebook
The clicking on the touch pad is not working
Check that the Enable Tapping box is checked. You can find it by clicking on the Pointing Device icon on the bottom right of the screen and then follow the links to the Device Settings...Settings...Tapping. Hope that helps.
Feb 18, 2009 | Acer Aspire 5735 Notebook
Touch pad not working
hmm... goto control panel, double click on mouse icon
click on Device Setting tab and Click on Enable button and finally................. :))
Thanks
Iqbal
Apr 06, 2008 | Acer Aspire 5630 Notebook
Acer aspire 5520 startup problem
Michelle-
I had the same problem with the cursor jumping around. My cousin bought the same computer and had the same problem! What she told me to do was go to the touchpad icon on the bottom right. Then click tapping and then check the box that says "tap off when typing."
It seems to have worked for us.
Jan 18, 2008 | Acer Aspire 5500 5570-2609 Laptop
Touch pad center click button no longer works
Near your clock, you'll usually find an icon for your touch pad (probably synaptics). Open this & select mouse properties, in there look under Device Settings & try the "Reset Devices" icon.
If that don't work, Click start>control panel (classic view)>mouse.
On the Touchpad tab, make sure the 'tapping' box is checked . Click apply, click ok.
If that doesn't work, click start>run, type devmgmt.msc
and click ok.
Click the plus to expand Mice and Other Pointing Devices.
Right click and uninstall any mouse or touchpad listed.
Reboot.
Let Windows rediscover and reinstall the touchpad drivers.
Good Luck!
Jan 09, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
102 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
