Question about Microwave Ovens
We received this mirowave as a replacement. We would like to install it, but cannot figure out the trick to removing the ventgrille to get to the mounting screws. We have removed the two screws holding it on and can give some movement but do not want to break it. Help.
  • arwhisenant Apr 05, 2011
    I'm sorry....it is a Dometic DOTR12CWIV/DORT12CBIV/DOTR12CSIV
  • 794 Answers
Hi arwhisenant,
I have the installation manual that you can download. It has detailed instruction as well as pictures that will make installation easy for you. Kindly click on this link.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 06, 2011
  • 1,543 Answers
This is a bit difficult because you do not list a model number, or even a brand name.
Some over the range microwaves have a few screws at the front edge of the top into the front grill. After removing screws in grill (front and/or top) many must be shifted a inch or so to the left to allow removal of the grill. Most OTR microwaves do not even require removal of the grill to remove micro from cabinet. Just remove screws from inside cabinet (cabinet floor into roof of microwave), allowing microwave to pivot down and forward, then lifting micro off back metal mounting plate.
Of course there have been many different mounting methods over the years, which is why listing a model number is important. (for example, the early OTR's: Remove top grill after removing it's two phillips head screws, remove right side grease filter on bottom, remove metal cover hiding multi pin electric plug, unplug multi pin plug, remove three phillips head screws from near front edge of microwave oven's bottom, side micowave forward out of outer case, proceed to remove outer case from cabinet)
Posted on Apr 05, 2011
Can ou please tell me wha the wattage is on a 1995 GE pscesaver Mirowave Model #JVM240wv and ser# of FM924649S?
The owner's manual (here) says on the front page that it is a 850W model.
If you need repair, see this link for more tips, or for a "drop-in" replacement, see GE support.
Oct 14, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Can the inline fuse on a kenmore microwave shut down the hole system
Yes! once the fuse goes on the inside, all power to the mirowave oven is removed.
Apr 23, 2012 | Microwave Ovens
How do I replace the fuse
Unplug mirowave, remove top, "several screws" look to the right where the keypad control board is, now look down where you will find a circuit board, nearby the fuse should be visable, "clipped in" pop it out and replace with the same current rating, assemble before test, "lethal voltages present"
Apr 20, 2012 | Microwave Ovens
How to remove maytag mirowave front grill clip
Get free pdf at www.manualowl.com Click on link.Jimmy
Apr 07, 2012 | Maytag Appliances Over-the-Range Microwave...
How do i replace the inside light in a ge mirowave model jvm1790bk
The inside light is not meant to be user replaced, so you would have to remove the oven from the wall to do it.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts (such as the bulbs) by entering your full model number here. That's how you can find where the bulb is.
Jan 10, 2011 | GE Profile Over-the-Range Microwave
The oven is not heating up but everything else is working.What is the problem
More than likely the Magnatron has gone bad. this is the device that atcually creates the micro waves that create the heat. They go bad after several years of use. They can be replaced but mirowave ovens are generally cheap enough to get a new on instead of repairing the old one.
Nov 27, 2010 | Belling Microwave Ovens
GE profile mirowave JVM1350WW002. Handle broken
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Oct 10, 2009 | GE Profile Spacemaker Over-the-Range...
BUY A GE SPACESAVER MIROWAVE JKP65WOV1WW ITS WHITE DISCONTINUED 25'X42' MUST FIT
If by chance you have that model and wish to replace it, GE customer service (found here) should be able to tell you what the "drop-in replacement" is for that model.
If that solution is not what you need, please reply back and clarify your problem.
Otherwise...
Jun 06, 2009 | Microwave Ovens
The turntable on my model kems307dbl4 has stop turning
remove the glass plate carefully.and check the gears it they are cracked or damaged it has to be replaced.if any thing is blocking the gears clean them.
Nov 13, 2008 | KitchenAid KCMS185J Microwave Oven
Microwave Ovens Logo
89 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
