Question about Candy AQW130 Front Load Washer / Dryer
I cant remove the filter on my Candy AQW Washing machine
    Brigadier General:
  • 6,277 Answers
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
Good luck
John C
Posted on Apr 05, 2011
Why is my Candy GODF800/L-80 washing machine leaking after I cleaned the filter?
Go to www.repairclinic.com and enter GODF800/L-80. You will be presented with a list of common replacement parts and may be able to view a generic Candy disassembly video. In the parts list, the filter may be identified as an assembly which would indicate more than one piece.
Aug 18, 2016 | Candy Washing Machines
My candy go w475 washing machines stop working, the stop buton flashing all the time, colse the door but still flashing any help plz
clean the filter empty the machine at the drain filter !!!
check for rubbish in the pump viens {power OFF}
kirby grips clothes wires coins etc
perhaps you dont have the manual how to keep it clean
http://www.manualsdir.com/manuals/242947/candy-go-w475-s.html
Dec 04, 2014 | Candy Washing Machines
Cant get filter box back in after cleaning it
something is blocking the box going back in
check for bits of metal {metal wires} parts from games and toys
like lego bricks or a coin or something
Aug 21, 2014 | Candy AQ130 Front Load Washer
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
Hi i have candy go washing machine it shows error cond e05 What to do?
E05 indicates that the pressure switch is stuck on full, this may be that your pump is jammed or blocked. Remove the filter and clean it out, also try to fish around in the tube that leads up to the drum. If this doe snot remedy the fault have it repaired by an engineer or someone whom has a rudimentary understanding of the mechanics of a washing machine.
Jan 08, 2011 | Candy GOY105 Front Load Washer
My Candy CNV 256 will not drain propery. I am
there is a pump filter at the front behind the kick plate . Turn machine off at wall . put towel's on floor remove kick plate with screwdriver carefully not to damage plate .remove screw from filter (if one is fitted )place shallow tray on floor under filter (baking )and carefully turn filter front there is always water in this part turn and pull gently water will now be filling the tray and towel's are getting wet clean filter and refit hope this works .post again if not
Feb 22, 2010 | Washing Machines
Unable to remove filter on machine
Assuming you have located the filter at the bottom front of washer, you unscrew it anti-clockwise to remove and clean.
If there is a small screw in the filter handle, then unscrew it first, before removing filter.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Candy AQUA1000T Front Load
Need to know where the filter is on a candy cn450 washing machine so i can clean it?
If `there is a removable plastic panel at the bottom front of washer, remove it ,and you should the filter there if it has one fitted
Unscrew the cover anticlockwise, remove and clean.
Plz rate my solution.
Thanks.
Jan 18, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Candy AQW130 Front Load Washer / Dryer Logo
322 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
