Question about KitchenAid KAWS850L Top Load Washer
I have a kitchen aid Model# KAWS850GQ1 How do I disasembled it
I suppect I have a broken Drive coupler- How do I take my machine apart to get to it?
  • 943 Answers
Thanks for the question AT the front of the console at each corner where the top meets the console you will see 2 screws remove them Lift the console You willsee 2 brass spring loaded clips remove disconnect wire connectione on the top pull off cabinet now you should see the pump & motor its usually the pump with all these parts off you can still put washer in fill &it will wash now you should be able to see your leak Thanks for the question THe appliance doc
Posted on Sep 11, 2008
. my machine will agitate but will not spin out. it just shuts off. could this be a timer or something else. the machine model is kaws850gq1
Posted on Sep 28, 2008
Washer fill with water model # LA4800XTW0 then just sits there no agiate no spin water will then drain once switch is manually advanced. Lid switch problem? OR direct motor coupler?
Hello, welcome to FixYa.
Based on your post, if you mean manually advancing the timer it will drain, it's a coupler. If you mean manually activating the lid switch, it is the lid switch or lid switch strike.
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...based on the model provided, it cover's yours)
Thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Aug 14, 2011 | Whirlpool Washing Machines
The agitator does not spin during a wash cycle and the machine makes a noise that seems like its spinning but not connecting with the agitator. Maybe a broken gear of some sort? How do I take the unit...
This is usually caused by the motor coupler. This is very inexpensive and easy to replace. Here is a video this will walk you thru this disassembling and replacing a motor coupler in a direct drive machine. It may be a different model but the troubleshooting and replacement will be the same. You can also enter your model # for your specific model to get diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Jan 25, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not agitate or spin
On Whirlpool brand made machines the drive coupler between the motor and the transmission is probably stripped out or broken and needs to be replaced.
Keep in mind that Whirlpool also manufactures: Estate, Roper, Kitchen Aid, some Kirkland and some Kenmore washers. All have the same coupler that gets stressed and breaks. A cause for this often times is overloading the machine.
After inspecting and finding the problem, make sure you have the model number and call your local appliance parts store or repair center and they probably have your part in stock.
Repairing a stripped out coupler is pretty easy for the doit yourselfer.
I suggest watching this video before attempting the repair:
http://www.youtube.com/watch?v=WLPGs2UMUJc
Apr 10, 2010 | Kenmore 24032\24036 Top Load Washer
What can the problem be when the agitator and tub do not spin or agitate? the washer fills with water, but agitator will not agitate and tub will not move. there is just a humming noise
Well, this is one of those times when it is important to note what brand of washer you have.
The fact that you hear something humming tells me that the motor is turning and that tells me the lid switch is activated and functioning correctly
If it is a whirlpool brand made machine the drive coupler between the motor and the transmission is probably stripped out or broken and needs to be replaced.
Keep in mind that Whirlpool also manufactures : Estate, Roper, Kitchen Aid, some Kirkland and some Kenmore washers. All have the same coupler that gets stressed and breaks. A cause for this is often times is overloading the machine.
Most other brands use a belt drive system and the belt probably burnt in two or broke. Again the cause in most cases is overloading.
Apr 09, 2010 | Kenmore Washing Machines
Seems like motor has lost power
This sounds like the black rubber coupler has broken. The teeth often get knocked off. Have a look at the part shown in hte pictures here:
http://kitchenaidblenders.co.uk/Home/tabid/36/p/Two-%282%29-KitchenAid-Blender-Coupler-%2b-WS-Fitting-Tool-9704230_2plusWS/ProductID/175/Default.aspx
Jan 22, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Top loading kitchen aid washer that shakes down the house
probably wouldnt look under hte agitator for problem. although the trick is to hold t he agitator while loosening hte bolt, it will then lifts right off after bolt removed., i would remove hte cover and perhaps look for a broken spring , bleach sometimes falls through rusting out metal brackets
Dec 05, 2008 | KitchenAid KAWS850L Top Load Washer
Clothes washer just makes a noise like a gear spinning ?
I was having the same problem with mine so I took it apart. There is a plastic coupler-like device that connects the drive motor to shaft which allows your "spin" cycle to commence. This coupler has posts in side it but they are under the little belt. My posts were all broken so the bottom piece of the coupler was spinning but the top was not, so it just made a humming noise. This part is available at
http://www.searspartsdirect.com
partNumber=3363664
Nov 24, 2008 | KitchenAid KAWS850L Top Load Washer
Kitchen aid washer
Hi , washer is not spinning . found motor coupler had broken . need help on the best way to replace .
Jun 08, 2008 | KitchenAid KHWS01PWH Global Horizontal...
KitchenAid KAWS850L Top Load Washer Logo
444 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
