Question about Dell Computers & Internet
Failed to detect one or more ATA drives during POST.
  • John Sparozich Apr 06, 2011
    Did you change something in the BIOS?
    Your Dell may have SATA drive installed.
    What Model Dell do you have?
  • 721 Answers
Need abit more details here. If it's windows 7, then you need to unplug all the drives exept the one you want the O.S. on. Get back to me.
Posted on Apr 16, 2011
Hard disk drive not detected during installing windows server 2003
It depends on what type of drive you are using. Plus, you may have to specify the array controller drivers if your are using the SAS (Serial Attached SCSI) drives.
May 22, 2013 | Dell POWEREDGE R610 (4640223) Server
How to set the JB Jumper Setting on a wd25eurs Harddrive
if its a sata hard drive there are no jumper settings the larger driver should take the job as primary
if you have an ide hard drive
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-1 means Pri slave
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
for the sata
What You Need
  • A Phillips screwdriver and four 6-32 UNC drive mounting screws.
  • A Serial ATA interface cable (sold separately). Maximum length is 39 inches (1 meter).
  • A Serial ATA-compatible power cable or adapter (sold separately).
  • A version of Windows with FAT32 or NTFS file system.
  • A system with a motherboard that has a Serial ATA connector on it, or a Serial ATA host adapter and available PCI slot in which to install the adapter.
Refer to your computer system documentation to see if your system supports Serial ATA on the motherboard and to locate the Serial ATA connector.
If your system does not have a Serial ATA connector on the motherboard, you must purchase a Serial ATA host adapter that is compatible with your computer and operating system and install it with the appropriate device driver according to the host adapter manufacturers installation instructions.
Note: See our list of companies that sell Serial ATA components including host adapters, cables, and power adapters.
Handling Precautions
  • Disk drives are fragile. Do not drop or jar the drive. Handle the drive only by the edges or frame. Keep the drive in the protective anti-static container until you are ready to install it to minimize handling damage.
  • Drive electronics are extremely sensitive to static electricity. While installing the drive, wear a wrist strap and cable connected to ground.
  • Turn off the power to the host system during installation.
  • Do not disassemble the drive. Doing so voids the warranty.
  • Do not apply pressure or attach labels to the circuit board or to the top of the drive.
Attaching Cables and Mounting the Drive
1. Attach one end of the drive interface cable to the Serial ATA interface connector on your computers motherboard or Serial ATA host adapter (see your computer manual for connector locations). Host adapter configuration is shown below.
Note: Serial ATA connectors are keyed to ensure correct orientation.
2. Attach the interface and power cables to the drive.
3. Secure the drive using four 6-32 UNC mounting screws in either the side-mounting or bottom-mounting holes. Insert the screws no more than 0.20 inches (5.08 mm) into the bottom-mounting holes and no more than 0.14 inches (3.55 mm) into the side-mounting holes.
Note: Do not overtighten the screws or use metric screws. This may damage
the drive.
Configuring the BIOS
Close your computer case and restart your computer. Your computer may automatically detect your new drive. If your computer does not automatically detect your new drive, follow the steps below.
1. Restart your computer. While the computer restarts, run the system setup program (sometimes called BIOS or CMOS setup). This is usually done by pressing a special key, such as DELETE, ESC, or F1 or F2 during the startup process.
2. Within the system setup program, instruct the system to auto detect your new drive.
3. Save the settings and exit the setup program. When your computer restarts, it should recognize your new drive. If your system still doesnt recognize your new drive, see the troubleshooting section on the back of this sheet.
Note: Serial ATA is a new interface type.
Some older systems may see the drive and classify it as a SCSI device if you are using a Serial ATA host adapter. This is normal even though this is not a SCSI disc drive. Many systems BIOS will not identify a Serial ATA drive connected to a PCI SATA host adapter.
This is because a PCI SATA Host Adapter has its own BIOS which is used to identify hard drives connected to it which is separate from the BIOS of the computer.
To determine whether or not the SATA Host Adapter is detecting the Serial ATA hard drive, please consult the documentation provided by the Serial ATA Host Adapters manufacturer. This does not affect drive performance or capacity.
hope it helps
Apr 14, 2012 | Western Digital Computers & Internet
I have a Galaxy Metal Gear Box. It will house two hard drives. It refuses to post the second drive. I just put a brand new one in it. Same result. Rocky
If both drives are SATA (not "parallel-ATA") drives, then "swap" the physical location of the two drives, to see if only the "top" (or the "bottom") drive is NEVER detected. Or, if the "detected" drive moves after the drives are swapped, then the non-detected drive has a problem. In that case, remove the "good" drive, to see if the "bad" drive can be detected when it is the only active drive.
Jan 11, 2011 | Galaxy Metal Gear GMG 3538UCBLK 35 Dual...
Hard Disk Problem
it seems as serious disk drive error to try fixing any errors that may be present on drive please run from command prompt [as admin] cd /D <faulty drive letter> then chkdsk /r if asks to unmount <or scan after reboot if it is sys disk> say Yes <lonely Y also does the job> this should fix the trouble, if not please send message
Oct 09, 2009 | Computers & Internet
Trying to locate a HDD caddy/Connector
In normal circumstances it would be a USB 2.0 but I don't know what you are connecting it to.
Jul 29, 2009 | Computers & Internet
Could not detect ATA drive
Get into the bios/setup of the server (hit either of f2 or f10 or del keys during start up) and somewhere you should have an option to set the ATA/SATA hd to legacy mode, that should do it.
Regards
Mar 13, 2009 | Cisco MCS-7825I1 (MCS7825H1ECS1) Server
Computer will not boot - no signal getting to monitor
Have you check the video card, is it loose, not sitting right, beeps are either memory, video or a bad mobo. here's a list of beep codes; the numbers represent the amount of beeps
1   The memory refresh circuitry has failed 2   Parity errors have been detected in the first 64 KB of memory 3   A failure has occurred within the first 64 KB or memory 4   System Timer failure: Timer 1 on the mainboard does not work properly 5   The CPU has generated an undetectable error 6 8042 Gate-A20 failure: BIOS cannot switch the CPU into protected mode 7   The CPU has generated an exception error 8   The video adapter is missing, or the memory on the adapter has generated a failure 9   The ROM checksum value does not match the value in BIOS 10     The shutdown register for CMOS interrupt channel 2 has failed POST; the system board cannot retrieve CMOS contents during POST 11 Level-2 cache memory has failed the tests, and has been disabled 2 short POST has failed, caused by a failure of one of the hardware tests 1 long, 2 short Failure in video system: a checksum error was encountered in video BIOS ROM, or a horizontal retrace failure has been encountered 1 long, 3 short Failure in video system: the video DAC, the monitor detection procedure or the video RAM has failed 1 long POST procedures have passed
Feb 21, 2009 | Asrock K7VM2 Motherboard
Disappearing Drive
Sometimes this is a signal of a degrading PC, either the drive or the PC board. The drive is detected during POST, and if it does not respond then it will not appear on the drive list. Check for poorly made connections in the ribbon cable (if ATA)
Jun 12, 2008 | Computers & Internet
HDS728080PLAT20
the comp detecting the HDD is irrevelant, the fact it detects it means only it has detected the electronic part of the drive, if the actual mechanical part of the drive, and the platter are failing, then it will not work, i suggest taking it to someone who can test it.. you will know then
Dec 08, 2007 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Computers & Internet Logo
566 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
