Do you know the power ouput from this power unit, input is 120v 60hz 15w, but I cant find the output. Thanks
    Brigadier General:
  • 8,546 Answers
Whatever it is we're talking about isn't much. It only uses 15 watts of electricity so the actual audio output would be a fraction of that as most energy is wasted as heat.
Posted on Apr 05, 2011
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
Misplaced my power supply for my 1950x pencil sharpener and can`t find the output or polarity labeled on the thing?
I have the same sharpener. Input is 120v AC 60Hz 16W which is what comes out of the wall in USA.
Output is 12V 800mA and the polarity is positive in the inside of the plug. I'll try to attach a photo to this post.
misplaced-power-supply-1950x-pencil#solution-section-kjptrdwcwv032w1lziamb525-3-0.jpg
Mar 02, 2014 | Boston Acoustics Mighty Mite Electric...
Mixed up my power supply for my dvd1170e external drive what is the correct input andoutput for this device?
You need one with the following attributes:
Output Voltage: 12 Volts DC
Amperage: 1.8~2 Amps
You can buy a replacement at http://www.lcdpayless.com/productpage.php?productId=8562
Nov 30, 2011 | HP dvd1170e DVD-RAM Burner
If someone has an original Sega Genesis 2 power supply, can you tell me the exact volts, amps and polarity that uses? I know there's a lot of adequate replacements, but I want to use one that matches Sega...
Well I'm happy to say that i have a genesis 2 power supply on me Its specs are
  • Input: 120v AC 50 Hz 15W
  • Output: 10v DC 0.85A
If you don't have the required power supply already or can't find one you can find a replacement here
Feb 11, 2011 | Sega Genesis 2 Console
Need to convert 120V AC/DC current to 120V AC 60Hz 15W
there is no such thing as "ac/dc" current-its either one or the other--if its a 120 Volts then chances are it is AC already-at 60hz---the 15 Watts or any Watts is the amount of draw from the unit-not the power supplied to it- Watts= Volts(supplied)/Amps(being used) if you only want to supply 15 watts then reduce the amps (with a fuse) to .125amps
Mar 26, 2010 | Computers & Internet
Replacing Microwave turntable motor
if they are physically alike use it,the units are both120 volt units,you cant operate a 210 volt motor on 120 volts w/o an inverter furthermore it would be 220 volts for that type of motor,its just a production run #
Aug 25, 2009 | Microwave Ovens
NPS-200PB-73M
SPECIFICATIONS:
Dimensions 5.9"W (150mm) x 3.4"H (86mm) x 5.5"D (140mm)
Special Features Dell Proprietary Main ATX & 6 Pin Auxiliary Connectors
AC Input 100-120V/7A 60Hz 200-240V/3.5A 50Hz
DC Output Voltage 3.3V 5V12V
Total Output Max Load 200W
Regards.
Jul 20, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
YST-SW215
Do you have the input voltage switch set to 120V 60hz. There is a switch that should change from 120v/60hz to 220v/50hz. In the US this should be on 120v/ 60hz
Jul 02, 2008 | Yamaha YST-SW215 Subwoofer
Power supply for a 5500C
Delta Electronics
AC Adapter model ADP-36XB REV. B
Input:AC 100V-120V~850mA 50/60Hz
Output: 24V 1500mA LPS (Center positive)
Made in Thailand
Jul 02, 2008 | HP Scanjet 5500c Flatbed Scanner
23 people viewed this question
 Grubhead
Grubhead
