Question about Garden
Look for instruction for Snap On Timing Light model MT2261
  • 710 Answers
You can get a manual from any SnapOn dealer.
However, I found a forum that answered this question from someone. He stated that he stole the directions from another site. I'll paste his directions here:
Reset button - resets the light to zero
Tach/Adv - Toggles between the tach setting and the advance settings.
Flash - On/Off for the strobe
Dec - Decrease the setting
Inc - Increases the setting
Basic use. Hook up the battery leads, Clip the pickup on cylinder number
one. It should come up and ask you to select number of cylinders.
Now it will display the rpms of the engine and can be used as a standard
timing light.
To use the advance feature you need the specs for the engine. They will
tell you that base timing should be something like 4 degrees at 500 rpm.
and that full advance should be something like 30 degrees at 1500 rpms.
Now use the Tach/Adv button to select degrees. Use Dec/Inc to adjust
that number. Then switch to tach and adjust it to the correct number.
When you use the light set properly it will read zero degrees at the set
rpm IF the timing is correct. Use the same thing to check full advance.
I hope his instructions are on the mark.
If you appreciated my answer, I'd appreciate a vote. Thanks,
Handie Andie
Posted on Apr 05, 2011
Where can I find snap on manual for MT2261
Others on internet mention calling Snap On and a free manual might be sent. Otherwise this was found to explains basics:
timing light.
Dec 01, 2014 | Baby Gear
Looking for a manual for a snap on timing light MT-1261LA
Hi there:
This its a generic instructions about how to work...
1.- Locate the timing marks and the metal timing pointer located on the lower engine pulley. It might be necessary to turn the pulley with a wrench until the marks appear.
2.- Refer to the engine's specifications manual to determine what the correct timing mark is, and mark the proper timing mark on the pulley with a piece of chalk.
3.- Attach the timing light to the engine. The timing light has three cords that extend from the bottom of the light. Two of the cords have colored alligator clips on the end, while the third cord looks like a rectangle with a hole in the middle. Clip the red alligator clip to the positive side of the battery, which can be identified by the "+" sign. Clip the black alligator clip to a clean metal surface. The black clip acts as an electrical ground. Clip the cord that looks like a rectangle around the spark plug wire for the number one cylinder. Refer to the engine's manual to determine which wire is for the number one cylinder.
4.- Disconnect and plug any vacuum lines that are attached to the distributor. A vacuum line can be plugged with the tip of a pencil or golf tee.
5.- Ensure that the timing light's cords are free from the engine's fan, then start the engine.
6.- Point the timing light at the chalk mark on the lower engine pulley and the metal timing pointer, then pull the trigger on the timing light. The timing light will produce a strobe effect. The engine will be properly timed if the chalk mark and the metal timing pointer align with each other.
7.- Adjust the timing, if necessary, by loosening the single bolt that holds the distributor in place and twisting the distributor slightly until the chalk mark and the metal timing pointer are in alignment, then tighten the distributor's bolt and reconnect the distributor's vacuum line.
Other details could find on thie other PDF links:
- InstallationInstructions/100/121/121-8990
- Advance Timing Light_MNL
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 22, 2012 | Cars & Trucks
I just need to get the instruction manual for my baby trend snap n go double stroller for model # 1304tw?????
hi
these are for the newer model im not sure what differences there are
http://www.babytrend.com/pdf/1305TW_EN_1109.pdf
Oct 11, 2010 | Baby Trend Snap-N-Go LX Double Stroller
Will snap the pic but will not save it to the sd card. have tried numerous cards but still the same thing.
It keeps freezing up. It will act like it is taking a picture and will freeze on snap and then THe red light will stay on. WE bought it at a rummage sale and dont know if it is tore up or an easy fix. Dont know where can find instructions to it
Sep 21, 2010 | Bushnell Trail Sentry 11-9200 Digital...
We have a Snap n Go model 1308, and need to know how to adjust the bar for a Graco snugride 1756475
Hello
Please click on this link. This is the instruction manual for your snap n go model. http://download.gracobaby.com/ProductInstructionManuals/ISPC090BB.pdf Please let me know if this works for you.
Thank you
May 02, 2010 | Baby Trend Snap-N-Go LX Single 13100/13108...
How to set the timeing on 1990 acura integra
YOU NEED TO CONNECT A TACHOMETER ACCORDING TO THE MANUFACTURERS INSTRUCTION.ON THE 1990 - 1993 MODELS USING A SUITABLE JUMPER WIRE CONNECT THE GREEN AND BROWN TERMINALS OF THE IGNITION TIMING ADJUSTING CONNECTOR LIGHT GRAY WIRE LOCATED UNDER THE RIGHT SIDE OF THE DASH.MAKE SURE ALL WIRES CLEAR OF THE COOLING FAN AND HOT EXHAUST MANIFOLDS.START THE ENGINE POINT THE TIMING LIGHT AT THE TIMING MARK POINTER AND THE CRANKSHAFT PULLEY.ON THE 1990 - 1993 MODELS THE POINTER SHOULD BE ON THE RED MARK 16 DEGREES BTDC ON THE CRANKSHAFT PULLEY AT 700 - 800 RPM.IF NECESSARY ADJUST THE TIMING BY LOOSENING THE DISTRIBUTOR ADJUSTING BOLTSSLOWLY ROTATE THE DISTRIBUTOR IN THE REQUIRED DIRECTION WHILE OBSERVING THE TIMING MARKS.AFTER MAKING THE NECESSARY ADJUSTMENT TIGHTEN THE HOLD DOWN BOLTS TAKING CARE NOT TO DISTURB THE ADJUSTMENT.REMOVE THE JUMPER WIRE.
Feb 28, 2010 | 1990 Acura Integra Hatchback
Need schematics for guarddog model number rb24 low water cutoff
http://www.mcdonnellmiller.com/MM-Installation-Instructions.asp
This link will give you the needed info, just have the exact model number, as there are a couple rb24.
Good Luck
Oct 02, 2009 | Miller Mcdonnell Swa-150s-md Snap Switch...
Instruction Manual
You can download the operating instructions and warrenty info as well as get and additional info needed directly from panasonic :) here is the link hope this helps
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/D-snap-SD-Cameras/model.SV-AS10S
Nov 16, 2008 | Panasonic D-snap SV-AS10S Digital Camera
Garden Logo
1,233 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
