Question about Golden Technologies Companion II Travel Scooter
Brake on motor drags battery down where can i get a new or rebuilt motor
  • 692 Answers
Contact Golden Tech @ 800-624-6374 and ask for tech support Then explain your problem and ask if you can get just the brake assembly or have to replace both motor and brake. Cheaper for you if you can get just the brake Hope this helps you
Posted on Apr 05, 2011
Chair is slowing down. Batteries are fully charged.
How old are the batteries? Even fully charged older batteries can be weaker and not give you as much power to keep the speed at what you are used to. Now a dragging bake can cause you to go slower and also drag the batteries down quicker. Try driving the chair and after awhile check each motor to see if they feel overly warm or hot If one or both feel very warm or hot then I would have the brake or brakes checked If they seen ok I would get the batteries replaced
Feb 26, 2011 | Electric Mobility Invacare Pronto M41...
Brake seems to stick on causing battery to run down
Sounds like you have weak batteries or a bad brake. You can measure the brake resistance at the connector between the front and rear halves of the scooter. The brake is good if the resistance measures between 30 to 65 ohms.
You should load test the batteries to see if they are good. It takes battery power to run the motor and release the brakes. Weak batteries will cause the brakes to drag and the scooter to run slow.
A new brake costs about $70 and new batteries start at $40 each.
If you do not have a beep fault code, nothing has burnt out yet. I would have the scooter checked out soon by a qualified technician. Hope this helps.
Jan 08, 2011 | Pride Mobility Products Go-Go Elite...
Starter turns motor to slow to start, it has new battery,new starter,new silinoid.
There is a test you can run on the starter but you need special ewuiptment to perform this test. You probably can take the starter out and take it to a local shop and they can test it. It sounds like the starter is dragging and probably needs to be rebuilt.
Nov 05, 2010 | 1979 Harley Davidson XLH 1000 Sportster
I have just fitted new battery to my pride sonic but will only move very slowly even at maximum speed adjustment
Hi. Did you fit one battery or two new ones. It never pays to fit only one battery.
Have you checked for a high/low switch, sometimes called indoor/outdoor switch.
Check motor and battery connectors.
Check motor current ( amps ) with an amp meter to see if the motor is faulty.
Check brake unit is not causing drag on the machine.
Good luck. Neil.
Feb 09, 2010 | Health & Beauty
The right front brake drags and gets hot
When it drags, loosen the bleeder, if it releases, the hose is bad, if it does not release, the caliper is bad.
Dec 30, 2009 | 1996 Ford Taurus
Rear disc brakes drag after installing new pads
Just did my rear brakes this weekend, Monday had a very slight drag. Noted that when I installed new pads I had to tap them on. That shouldn't be. When brakes are released, there should be enough play to allow the pads to back off the disc. Tonight, I removed the pads and filed down the ends of the tips that go into the top and bottom channels until I could install and remove them with fingertips, that gives them enough play to grab and release. Drag disappeared; the old girl ran like she should.
Jan 18, 2009 | 2000 Chevrolet Silverado 1500
Pride legend xl
Had a similar problem with my shoprider te888's there are 2 possible solutions that I have found.
1. dirt had been picked up in the pad that acts as a brake, causeing the motor to drag and speed up, found this after almost burning my hand on end of motor with brake. disassembling the brake and cleaning with an alchohol soultion fixed this one.
2. Loose wire to battery post, or corrosion on battery connectors can cause this too. found loose terminal on battery by tightening nut where wire attached.drove me nuts for days till I decided to tighten with wrench rather than finger tight... On my scooter it would slow down do to excessive current draw because of bad connection and controller would shutdown, which meant ubrut stop. Showed up mainly when climbing long grade up driveway.
hope this helps
Oct 16, 2008 | Pride New Mobility Legend 4 Wheel Scooter
Golden Technologies Companion II Travel Scooter Logo
105 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
