Question about Hampton Bay 24002 Ceiling Fan
Fan on I have a hamptom bay fan but I can't turn the fan off. I trouble shoot the remote control playing with all the switch Settings. what do i do know. There is no switch in the switch box to turn the fan off neither is a switch in the room. the fan has been running on In high for the last week. thanks for your Attention.
  • Roberto21 Aug 06, 2008
    matt i think this should help. I tried positions switches in the remote control, i realize that I need now to really match the ones with The receiver. Let me try tomorrow to see if it works. If you want to check with me my email address is [email protected]
    thanks For you imput, Ed.
  • 417 Answers
I copied and pasted this from somewhere else, but this might do it, youll have to shut the breaker off at the fuse box first to gain access to the upper canopy..
There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Hope this does it
Matt
Posted on Aug 06, 2008
6ya staff
SOURCE:
Remote Not Working
This is tough to trouble shoot . IT might be the control or the controller. Take the remote to home depot and see if they have any fans that it works on that you can test it on. If it is the controller in the fan then you have to take the fan down and remove the controller.
Feb 16, 2013 | Hampton Bay Dryers
Battery good....remote light comes on....
Most Fan Remotes have to have the Battery compartment opened and the tiny rocker switches changed as well as the FAN receiver,could your child do that?.Try changing the Batteries.Good Luck.
Sep 11, 2009 | Universal Remote Control Hampton Bay...
Instalation tips, no manual with used fan
Hi, The bracket is like a cup with the downrod fitting into in with a ball and socket type arrangement. When the downrod ball is in the socket there is enough room to slide the receiver in, fold the antenna over the receiver when you put it in. It does not need to stick out. The whole thing is covered with the bracket cover and nothing shows. Good Luck, this should Fixya!
Mar 25, 2009 | Universal Remote Control Hampton Bay...
Fan and dimmer remote does not work
The remote is a Hampton Bay remote that should dim the light and fan on and off. I replaced the battery and do not have a red light when I press the button. Light and fan does not turn off with remote.
Mar 01, 2009 | Universal Remote Control Hampton Bay...
Hampton Bay ceiling fan, Remote does not turn light off
if you have the remote controll for both the fan and light you can have the controll on both the fan and light...
other wise it can't
Dec 08, 2008 | Hampton Bay 52 In. White Redington...
Hampton bay fans
inside the remote, and inside the transmitter above the fan there are 4 tiny keys that set the frequency. set each frequency different then the remotes will only operate that fan. However if two lights r on and one off, when u turn the switch off they all go off, and when u turn it back on the same ones should come on. Then label the remotes!!!
Jun 04, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Remote to fan won't work
Try this link for the ceiling fan remote it should be remote style M. I want a spare so I found this web page (page down)http://www.eceilingfans.com/ceiling_fan_remote_controls.html
Jan 20, 2008 | Universal Remote Control Hampton Bay...
Hampton Bay 24002 Ceiling Fan Logo
127 people viewed this question
Top Hampton Bay Dryers Experts
Ronald Buckner
Level 1 Expert
Donald Klecher
Donald Klecher
Level 1 Expert
Gene Pitts
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
