Question about Mercury Boating
Top cylinder is not firing on older 60 hp mariner
    Novelist:
  • 184 Answers
You might want to decide if it is spark fuel first. Easiest way is to short squirt some starting fluid in the top carb and see if it sputters. Don't worry about oil mix as there is plenty up there from not firing. If it is just one coil not firing, (assuming it's patterned after the Mercury) exchange that coil for one on the motor that is firing. If the problem follows the coil, buy a new coil, if it stays with the top cylinder, you will need a set of triggers under the flywheel.
If you had luck with the carb, rebuild and adjust them all, getting a good link and sync job on them so they all open at the same time and all go to WOT at tne same time will make that motor fly.
Posted on Jul 29, 2012
    Genius:
  • 1,140 Answers
Coil, wire, plug
Posted on May 20, 2011
How do i top up the lubricating oil in the hydraulics of a mercury outboard engine
I suppose you mean the oil in the Trim system...
Lift the engine all the way up,
Place the jackstand to keep the engine fully up.
You'll see a plastic plug in the center cylinder.
Unscrew that plug. ( There can be some pressure, take care of your eyes!)
Fill with ATF-oil till the level is at the bottom of the plug hole.
Screw the plug back in.
Lower the engine.
Done!
Sep 28, 2016 | Clymer Mercury/Mariner 2.5-60 HP...
Mercury mariner 2 stroke 60 hp starter motor removal problems
there are 2 clamps on the starter , top and bottom 2 bolts in each ! isolate the battery then disconnect the wires off the starter and remove the clamps and starter should come off !
Mar 09, 2015 | Boating
Whats the firing order on a mercury 500 thunderbolt marine engine ?
Remove the 4 spark plugs , number 1 is the top piston so put it to tdc then with a screw driver feel through each plug hole for which is the next piston to come up to tdc etc etc till you have written the order ! 1,2,4,3 or 1,3,4,2 !!
Oct 14, 2014 | Clymer Mercury/mariner 75-275 Hp...
How do i fix a mariner 60 outboard motor that has fuel starvation?
have you checked the fuel pump diaphrams are ok and are the connections on the fuel tank and line ok ? primer bulb not sticking ? carbs clean ? fuel pump connection to crankcase ok ?
Apr 26, 2014 | Clymer Mercury/mariner 2.5-60 Hp...
How do i set timing on a 1996 mariner 40 hp 4 cylinder 2 stroke outboard?
timing marks on flywheel and a pointer above the carbs , under the flywheel there is an adjustable rod from the trigger to the throttle linkage ! strobe light required , cant remember timing off top of my head as out so google it !
Aug 21, 2013 | Clymer Marine Maintenance and Repair...
1984 150hp yamaha outboard is not firing in #5
Stator delivery to the coils.
Sep 20, 2009 | Boating
Need firing order for a 86 chrysler outboard boat engine
Firing order 1 2 3 is common on most three cylinder outboards. 1 3 2 is the only other combination.
Jul 03, 2009 | Raymarine Linear Feedback Unit For...
Boating Logo
150 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Joseph Hoffmann
Steve
Steve
Are you a Mercury Boating Expert? Answer questions, earn points and help others
