Question about DSC Lcd-4501 Maxsys Programmable Lcd Keypad Message
I have a Maxsys LCD4501 alarm system. The door chime won't turn on. But everything else seems to be working. There is no battery that I can see. How can I fix this?
2 Suggested Answers
  • 17 Answers
SOURCE: my DSC security system is reading
First of all go to your security box.Now you will have to find where all the sensors conect to the panell.These area's on the board are called zones such as zone 1 zone 2 and so forth.Chech and make sure no wires have came loose from the screw termanils also make sure their is no corrision (good contacts are key).If this doesent work you will need a magnet find out which zone you are having trouble with such as front door back door window ect.Now their are two different sensers one is a flush mounted senser this will look like a little box on the frame of what ever it is securing.The other one will be a inset one this will be harder to find.It will be inside the frame of what ever it is securing.In any case you wil need to run the magnet over this device and see if the panel will reset.If this hapens then you know that their is something wrong with the orig. magnet.(When you shut the door or window the orig. magnet will align with the senser).Some times the distance between the senser and the magnet will effect the senser.If the senser is a flush mounted senser then their will be some wires you can acess to see if they are making contact.
((((( I DO NOT RECOMENT THIS ONE. IF YOU TRY THIS ONE YOU WILL NOT BE PROTECTING THIS ZONE AND SOMEONE CAN NOW BREAK IN )))))The next thing to try is to simply look on the panel door and read where it says which resistor it needs and where it goes on the panel in relationship to the correct zone buy the resistor and install it in the panel.
((((( I DO NOT RECOMEND THIS ONE. IF YOU TRY THIS ONE YOU WILL NOT BE PROTECTING THIS ZONE AND SOMEONE CAN NOW BREAK IN)))))The next thing to try is the zone bypass.The instructions on how to do this should be on the back of the key pad door.
The next thing to try is to look in the senser to see if it has a battery.Some sensers have a battery and they need to be replaced from time to time.Now I have been asuming that this is a senser on a door or a window but their are other sensors that are optional on this panel as well.Check all wires on these batterys and make sure all outer housings are securly on the sensors.
If none of this works then you probably either have something wrong with the wireing or the panel its self is faulty.If so contact a security technician.
Posted on Jul 30, 2009
1997 dodge caravan, full battery, turn key and it clicks, door chime buzzes, wont start. what should i look at?
Corrosion at the battery cables first. After that, remove the alarm system. Fix the wires as you go.
Mar 17, 2015 | 1997 Dodge Grand Caravan
Key fob don't work and chimes 6-8 times when i turn off
you have a aftermarket alarm system. you will have to take it to an alarm specialist. (it also could be a bad battery in your remote)
Jul 18, 2014 | 2000 GMC Yukon Denali
Location of tail gate alarm on 2004 Chrysler Pacifica
you may have a bad switch which is located on the latch asm
Sep 03, 2012 | 2004 Chrysler Pacifica
Does the bcm control the alarm in a 2006 monte Carlo? I can't seem to get the alarm to go off. I've also noticed that I have no chime and turn signal sounds. I just recently purchased this car and...
The no chime and turn signal has nothing to do with the alarm. You have a issue with power supply to turn flasher and door chime. The alarm consist of The door ajar switch,body control module,front door lock switch,power door lock switch. You need to check your fuse for turn signal and the door chime
Feb 22, 2012 | 2006 Chevrolet Monte Carlo
How can I reprogram my Jaguar X Type Key so I can unlock and lock my doors?
if your just programming the fob to the module and it has not been replaced and your just needing a manual reset,then follow the folowing procedure:
1 Insert key into ignition
2 Turn key to 'I"
3 Turn key "II" and back to 'I' quickly 4 times
4 Alarm system will chime once when key is back to 'I' for the
fourth time
5 Remove key from ignition
6 Press any button on each key fob and alarm system will chime
for each fob if it has been programmed correctly
7 Press unlock/lock/trunk etc to make sure everything works
Dec 12, 2011 | 2003 Jaguar X-Type
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
I have a byron SX85R plug in wireless door bell, i need to change the frequency/ or code, keep false alarming, cant find the instructions , also with the alarm, is a batterie alarm no. SX81R, which came...
From User Guide: Interference from a similar unit operating nearby: a) simply remove the batteries from the push button and door chime units and rest for 10 seconds, this will erase memory b) Insert the batteries into the push button and door chime units, the door chime unit will give 2-beeps to indicate that it is ready for the new registration code. Press the Push Button once, it will generate a new operation code randomly and send a wireless ignal to the door chime unit and it will sound to indicate that new operation code is registered and memorised.
(Note with this unit SX85R the door chime is mains powered, not battery powered, but above instructions are the same)
Oct 10, 2009 | Bell Cocoon Child Carrier
2004 Ford Explorer not starting
Is the engine turning over? When you turn the key to the on position, does it behave normally? IE, do the battery and airbag and other lights come on when you turn the key to on position?
Dec 24, 2008 | 2004 Ford Explorer
1995 Lincoln Town Car-Electrical system will not shut off
There seems to be a Problem with the electronic part of you Ignition switch. Good Luck
Nov 30, 2008 | 1995 Lincoln Town Car
1997 venture keyless remote programming
SYSTEM OPERATION
System warning lamp located on top of the instrument panel
Press UNLOCK button once , turns on interior lamps and deactivates alarm (if fitted)
Press UNLOCK button twice w/in 5 seconds unlocks all doors, turns on interior lamp and deactivates alarm (if fitted)
To activate alarm system (if fitted):
Switch ignition OFF
Open driver's door
Press Lock button on remote
Close Driver door
warning lamp will flash when system is activated
Press remote power sliding door button will open sliding door (if fitted) only if unlocked first
Pressing remote panic button:
*Sounds horn intermittently
*Flashes exterior lamps
*Turns on interior lamps
**Pressing panic for the second time OR switching ignition ON deactivates alarm.
PROGRAMMING
Remobe key from ignition switch
Remove the "BCM PRGRM" fuse, from the fuse box
Close all doors
Turn ignition switch to the ACC position
With in 1 SECOND , turn the ignition switch to OFF then back to 'ACC'
(really, with in one second)
Open and close the driver's door. A chime will sound, indicating programming mode activated
Press and HOLD LOCK and UNLOCK SIMULTANEOUSLY untill a chime sounds 2 times ( about 15 seconds)
Repeat this exact procedure for all remotes to be programmed
Refit 'BCM PRGRM' fuse.
4 REMOTES MAXIMUM CAN BE PROGRAMMED
Aug 24, 2008 | 2000 Chevrolet Venture
DSC Lcd-4501 Maxsys Programmable Lcd Keypad Message Logo
210 people viewed this question
Top DSC Home Security Experts
Steve
don1956
Level 1 Expert
Tom Chichester
Are you a DSC Home Security Expert? Answer questions, earn points and help others
