Question about Samsung SyncMaster 940MW 19" LCD Monitor
Ive had my samsung 940mw for about 3-4 years, my son uses it as his tv in his bedroom. the other night it wouldnt switch off on the monitor itself so i turned it off at the plug socket instesd. when we tried to turn it on again the following day it just wouldnt turn on at all! no light came on either? is it fixable or will i have to get a new tv?
  • lisa163edwar Apr 05, 2011
    Thanks, but i forgot to say i also tried another power cable thats from my pc and is definately working but the tv still doesnt come on, which makes me think it has to be a problem with the monitor itself? what do you think i could do next??
    Guru:
  • 433 Answers
Monitor led didn't light mean power cable is damaged or monitor you can try
good luck
Posted on Apr 05, 2011
  • Nader Selim
    Nader Selim Apr 05, 2011
    sir that is mean the power ic need to replace , you need a technician
    best regards
  • Samsung Master
  • 1,684 Answers
This is a common problem with this unit after a few years of use. There are parts called capacitors on the power supply board that fail and this causes the power supply to not be able to power up correctly. Here is a link to a repair guide with dis-assembly and repair information.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/
This should get you back watching TV in no time at all.
I hope this helps, if so please rate my solution.
Posted on Jan 08, 2012
Have sound but no tv picture
That model used the same power supply that the Samsung 940mw uses and when the capacitors go out you get sound but no picture just like you are getting. The repair is easy, you just need to replace the bad capacitors on the power supply board. Here is a link to the repair guide for the 940mw that should help you get your 910 back going, same power supply so the same repair.
I hope this helps.
Jun 24, 2012 | Samsung SyncMaster 910MP 19" LCD Monitor
I have samsung syncmaster 940mw monitor. The monitor for the most part will not turn on. When the power button is pushed or attempt to turn on with the remote the little green pilot light will blink or...
That is a hell know problem with the 940MW tv/monitors. The power supply has failed because of parts called capacitors have shorted. If you can solder then you should be able to repair your monitor. Here is a link to the repair guide for this issue.
Oct 30, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
On and off switch not working
Hello Michael,
The most common problem with the Samsung 940MW units that don't turn on is a failure of the power supply board. There are parts called capacitors that fail which in turn causes the power supply to not startup correctly so the monitor never powers up. Here is a link to a repair guide that should get you back watching tv and using the monitor in no time.
Oct 13, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung SyncMaster 940MW will not turn on
There are broken/exploded capacitors on the power plate, it is a 5 Minute job to replace them.
Mar 13, 2008 | Samsung SyncMaster 940MW 19" LCD Monitor
Problem with tv turning off by itself.
I had a friend with the same problem. He had to clean the components and fans in the set. The accumulated dust had caused the set to run hot and a safety switch was the tv off. He purchased a few cans of compressed air and, as he blew the components and fans out, used a vacuum to capture the blown dust. Good luck.
Dec 27, 2007 | Samsung HL-S4266W 42" HDTV
No sound when on pc mode
Check if your PC can play audio on some other speakers or headphone. If yes, check your monitor audio cable connections. If no something's wrong with your PC audio drivers. Try re-installing them or could be a hardware issue with your PC. Get it checked.
Sep 29, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung 940mw intermittent power...
I don't have a solution but would like to compare information as i just started looking into this problem myself. 1. I bought my Samsung 940mw in March, 2006 but didn't start having problems with it until around April, 2007 2. I'll be using it as my pc monitor when the screen goes black and the power light stays solid green. The monitor doesn't respond to the remote control. Nor can i manually turn it off via power button BUT i can restore it by a) turning power off at the UPS outlet it's plugged into b) removing the monitor cable from PC port c) restoring power and waiting for the Samsung diagnostic message about no monitor detected then d) plugging the cable back in. My monitor image reappears. 3. fyi I only use the analog monitor input. Samsung also released a new driver which hasn't made a difference. Within just last couple months the monitor will sometimes just go black a coupla seconds and come back on without any intervention
Jul 31, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung SyncMaster 940MW 19" LCD Monitor Logo
489 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
