Question about Sparkle Power 400-Watt Power Supply
NO Signal Greetings, My computer has died. When I try to re-boot; my moniter indicates that there is "no signal". This computer is a home-made system w/dual drives- a monster. All fans run except the one on the power source: a Sparkle Power Model# FSP400-60GN. Any ideas... Thanks Rick
  • 781 Answers
I suspect that your power supply may have overheated if its fan is not working properly try another power supply
Posted on Aug 06, 2008
Fix blown out graphics card or corupt hd
nope it will be a graphics card problem, if it's on board graphics your only choice is to purchase a new graphics card I do not know what expansion slots you have you need to find that out and buy a corresponding graphics card
May 17, 2013 | Compaq Computers & Internet
After all connection still moniter showing no signal
You either have a problem with the monitor (probably not, since it is displaying a message) or the computer itself. I suspect that your computer is not sending a signal to the monitor. Most of the time this is either a problem with the computer not booting correctly or a video card problem. This is what you should be checking.
Try booting the computer with everything disconnected but the memory and CPU and video adapter. If you still have no signal, try swapping out or removing one stick of memory. If there is still a problem, then it's either the video card or the motherboard (assuming that the power supply is not bad).
Jan 07, 2012 | Computers & Internet
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
My emachine computer was working then just stopped, when I tried to turn it back on. the moniter is showing no signal received. I have tried checking the VGA connection, changing it out for another, no...
Try your monitor on another machine - if it is working you have operating system/hard drive/motherboard/memory/heating problems. You must work that out if the monitor is good.
Apr 01, 2010 | E-Machines eMachines Desktop PC
My acer switchs on but the moniter has stopped working it clicks back to standby and says no input signal
That is because no signal is sent from your computer to the monitor, I suspect your computer is not booting up. Does you computer sound a beep on boot-up? or no sound at all? Have you system unit checked on the nearest support center, or you can troubleshoot it if you want, just send here the details of your troubleshooting and we will be happy to guide you with that.
Nov 22, 2009 | Acer Aspire M1641-U1521A PC Desktop
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
Jul 25, 2009 | Compaq P 1220 22" CRT Monitor
Moniter says no signal
You may need to replace the moniter cord or check the video card on the computer.
May 31, 2009 | Acer Aspire™ T180 PC Desktop
Repalcing video card in emachine w3611
no signal try open your system unit get the memory then put it back then try to switch on your computer
Apr 07, 2009 | eMachines W3611 PC Desktop
Monitor will not boot up stays in sleep mode
Is your pc got beeps, if yes then try to remove and clean the memory and also the video card if it is add on card. and then insert it again test. if encounter still the same error then try to replace the memory.
please tell me more if ever what you encounter about the issues.
may this help,
melnavz
Oct 04, 2008 | HP Media Center m7060n PC Desktop
Sparkle Power 400-Watt Power Supply Logo
65 people viewed this question
Top Sparkle Computers & Internet Experts
David Payne
David Payne
Are you a Sparkle Computer and Internet Expert? Answer questions, earn points and help others
