Question about HP LaserJet 1020 Printer
My HP LJ 1020 is making a loud grinding noise when pulling through paper. Print quality is fine, but the tone is leaking inside the printer. I tried blowing out the toner dust and lubricating the rollers, but the sound persists. Is this because my toner is refurbished?
    Problem Solver:
  • 5 Answers
The problem of your printer is the main drive gear assembly, its located inside if you open the cover on the left side
Posted on Apr 06, 2011
Why is my printer making really loud grinding noise and will not feed paper or print
It sounds like a bit of paper is stuck somewhere in the paper feed route. Remove the toner cartridge and any other bits that pull out. Removable bits often have a green tag or finger grips moulded in to them. Do a careful check in the printer for any bits of paper or even a full sheet stuck somewhere. Carefully remove all rubbish and reassemble.
Dec 01, 2014 | HP LaserJet 1018 Printer
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Is this thing shot for good?
Did you remove the new cartridge to make sure it isn't a paper jam and also to get a better look at the interior?
Aug 23, 2014 | HP LaserJet 1020 Printer
Copies are coming out with a dark horizontal lines and printer is making a rather loud sound when paper is in printing process.
Two things that can cause print quality issues and noise.
1. The toner cartridge can cause lines and sometimes can make a squeaking noise.
2. The fuser can cause streaking and smudges on the prints and can cause a grinding noise if the drive gear is worn or the bushings are worn.
Oct 15, 2010 | HP LaserJet P3005 Printer
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Noise from HP LJ 1020
Change the gears , coz when the machine load or when you are printing the roller turn, and those roller has gears at the ends so when they are died they give those sounds, open the cover and try to detect which gear make this noise and change it.
Mar 01, 2009 | HP LaserJet 1020 Printer
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
Poor Print Quality
I would start by changing the paper or even leave the paper in the son for a while. Paper usually gets damp, espesially durint the evening and then using it early in the moring. If this do not work you will have to change the cartridge.
Mar 05, 2008 | HP LaserJet 1020 Printer
HP LP1020
ok, y solved linking the printer with the application provided with the dpr, PS-link, its added a new port and printer and works fine since. hope helpfull
Sep 12, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
HP LaserJet 1020 Printer Logo
602 people viewed this question
Ben Johnson
