Question about Trilogy Alarm Lock cylindrical w/privacy DL4100 or Prox PDL4100
I want to change the 6 number code for opening the door lock but cannot locate our original manual. Please provide directions to change lock code when you do have the old code.
  • 963 Answers
This link will take you to a PDF file of the programming instructions. It will require that you have Adobe Reader or similar installed to view the file:
http://napcosecurity.com/download/Res-Priv_DL4X00_WI1194B.18_PROG.pdf
Posted on Apr 10, 2011
How do I change the combination on I have a paragon digital lock & safe
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
Changing PIN on Key Pad
can you please provide the exact model number of your Security device...
Thanks
Jul 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
NOTE:
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
I CAN'T REMEMBER MY 6 DIGIT CODE AND CAN'T FIND MY MANUAL, I WANT TO RESET IT, CAN YOU PROVIDE ME WIT INSTRUCTION?
How can I program my electronic keypad lock when the instructions with the programming code have been lost?
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This number is the programming code referenced in the information for changing the entry code.
This link will take you to the page that you need to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Aug 24, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
I have the digital door lock, but the keys are sticking down and now the lock will not unlock using the code. I opened the back and tried changing the code. The tumblers will not fit into some the holes...
Contact Digital Systems at either of these numbers (located in Mount Pleasant, MI) for customer service:
(989) 773-2363
(989) 775-1411
http://lockeyusa.com/
email:info@lockeyusa.com
Aug 13, 2011 | Lockey Digital M210 Mechanical Keyless...
HOW I CAN REMOVE MY PATTERN CODE LG GT540
First Try it:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
OR:
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 24, 2011 | LG GT540 Cell Phone
Adobe reader s nokia x6 is locked
Set your mobile factory setting.But i think you have forgot the password .
FREE Site
http://www.mobileunlockguide.com/mug/mobile-phone/
PAID SITE
http://www.unlock-zone.com/
http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw
First Try it:
Defalt phones codes(NOKIA) is 12345 or 00000 u can use it
Default 4 Digit Security code(LG) 0000
Default 5 Digit user code(SAMSUNG): 00000
Default 6 code for (MOTOROLA)000000 or 888888)
Default 6 Digit Security code: 123456 or 000000 or 888888
Default 6 Digit Security code(SONY ERICKSON) no number
write down on a paper
OR:
Good by
Jan 06, 2011 | Nokia X6 16GB Cell Phone
I Forgot my Pattern on my Samsung Intercept Phone and i want to get an master unlock for it can reset the hole phone
FREE Site
PAID SITE
First Try it:
Default 6 code for motorola(000000 or 888888)
OR:
Jan 06, 2011 | Cell Phones
I hv a chinese phone and it's asking me 2 enter d lock password.
First Try it:
OR:
Dec 16, 2010 | Cell Phones
Does not drain water and door does not open
Fault code E2 refers to a clogged drain pump.The drain pump needs to be cleared from kinks.Sometimes replaced if damaged due to the clogs.Please provide me the model number so that I can get more info regarding this and can provide you with some internal diagrams which will make it easy for you to locate the drain pump.
Good luck with the machine.Please do rate my solution if accepted.
Apr 11, 2009 | Samsung Washing Machines
Trilogy Alarm Lock  cylindrical w/privacy DL4100 or Prox PDL4100 Logo
138 people viewed this question
Top Trilogy Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Trilogy Lock and Locksmithing Expert? Answer questions, earn points and help others
