Question about Canon PIXMA iP4000 InkJet Photo Printer
My Canon printer (IP4000) is showing that the print head is not working or is defective. Where would I e able to buy a new one
    Genius:
  • 1,044 Answers
Unfortunately you have not given the place where you are residing. Then it would have been easy to tell you the place where you can buy the print head. Anyway in the absence of the place I would advise you to go the retailer where you bought the printer. He can help you out to get the print head. OR Go to support web site of Canon and locate Canon service centers near your residence/city and then get in touch with them to get the part or ask them to fix it for you OR you can buy it on line from amazon.com, best buy,com, canon stores.
Posted on Apr 05, 2011
Hello, my canon ip4000 just won't print properly. i have been executing "deep cleaning" numerous times but the print out still has missing lines. i sent it to our local canon service center...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Aug 24, 2011 | Office Equipment & Supplies
Suddenly stopped printing all colors. Will only
Hi, it could be few things wich you having problem with.
First, how old are the ink tanks, it could be clodged.
Second the print head nozzles are clodged at that places.
Third, the purge unit does not work OK.
First remove all inks out and remove print head. Then on wet cloth, wet it with distiled water, few times press the bottom of print head ( nozzles ), then the 4 circles must change from colour to white. That means that nozzles are cleaned.
Dry head by pressing it on dry cloth.
Put it in, also the inks, and run few times the deep head cleaning. Every time take a look at print pattern.
If the head is to badlly clodged, test pattern would be just a little bit more better.
But now you know if the problem is in head or something else ( purge unit or inks ). The new head isnt so cheap regarding the printer so then the best solution would be to buy new printer.
If you do not want to buy laser colour printer, atleast buy one on wich ink tanks has printhead on. Its slightly costly, but you have one worry less - the print head is changed every time you change the ink.
Hope that helped
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Canon ip4000 remove print head
Hi! You may access tha manual by clicking here. Please use the set up instruction manual (2nd m,anual from the top). Thanks for visiting FixYa.com!
Jun 06, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My canon pixma ip4000 has stopped printing. It is going through the motions but the paper is coming out blank with nothing on it.
Hi
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your Canon PIXMA iP4000 InkJet Photo Printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Or possibly a faulty cartridge.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the Magic Inkjet Flush kit to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Nov 23, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Yesterday I got a message that the print head needed to be reinstalled. This morning when I turned on the computer, I found I couldn't turn on my Canon Pixma iP4000 printer. I checked the power cord, and...
The print head is what is holding your ink cartidges and can be removed. Do as it says and remove it and then reinstall it. If that fails to work, you can try going somewhere like Staples to pick up a new print head, if they have any in stock.
Thats a really decent printer by the way; a great deal when they came out and a solid performer.
Aug 05, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon Pixma IP4000 - will not print. Did maintenance cleaning and the 3E was not showing solid lines. Cleaned many times and finally took out ink & print head and cleaned off a bit and now won't show...
I'm not sure what you did. We have 3 MP780 and IP6000 and 9000 printers. The frequent problem have is streaking usually w/ refilled cartridges and even new cartridges. This is what we usually do:
1. Take the printhead out and dip it in 1-2mm depth hot water. Hopefully the water changes color and clears up the clog. Keep the Circuits dry. Wipe off excess water when you are done.
2. For really difficult clogs, if the hot water doesn't work I find a small rubber hose and syringe that encloses(meaning air tight) the mesh in the printhead where the ink goes in. I then pump air in to clear out the clog.
3. Since you have to do it for the Black 3e, you might as well do it also for all the others to make sure they are not clogged.
Make sure when you pump in the air the syringe is not touching the mesh in the printhead. If these don't work then you can try borrow the printhead of another printer and testing it out. If it works then you need to buy the printhead. If Canon has stock, you should get it fast. If not, and you really need to print either go to a printing service or buy a new printer. Good luck.
Nov 13, 2008 | Canon Office Equipment & Supplies
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Problem with canon pi 4000
I think you have to clean the print head.and if cleaning doesn't help you may have to get a new print head.
May 01, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Purple printing
I have the same problem. Just spent £50 on a new print head which did sod all. I suggest using an maintenance hammer then buying another printer.
Nov 29, 2006 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
48 people viewed this question
old marine
old marine
