I'm getting an OE message on the panel, and the washer turns off and there is water in the bottom of the washer.
    Brigadier General:
  • 6,277 Answers
Although you haven't mentioned the make or model, from the 'OE' I suspect it is an LG and the code means there is a draining error.
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 05, 2011
What do we when we replaced the pump on a frontload washer, LG, but still get an error message OE?
The DE Code indicates a Drain Error. This means that the washer thinks the water has not drained out of the tub within 10 minutes, which is an eternity for the washer. Since you have indicated that there is no obstruction in the hoses, and filter, and you have replaced the pump, then the only other parts that could be at fault would be the water level sensor, or the main circuit board. Replace in that order.
Aug 16, 2014 | LG Washing Machines
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
Apr 10, 2014 | LG WM-2277HW Front Load Washer
Door will not unlock and water will not drain also get an err.code oE
Hello & Welcome to FixYa
Correct, OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter located inside the bottom front panel for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Aug 10, 2011 | LG WM-2277HW Front Load Washer
Water is not draining.... OE symbol appears on display. Checked the connection up to sink and drainage out to garbage disposal. everything seems fine there!
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter by removing the bottom front access panel for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Jun 12, 2011 | LG LDS4821 24 in. Built-in Dishwasher
"OE" message
OE is actually DE - Drain Error. Pop open the little door on the bottom left of your washer, and unscrew the cap on the little tube on the left. ***Water will drain out!***
Once the water is out, unscrew the bigger tube on the right. This holds your drain filter. It is likely clogged, so clean it out and reinstall the filter and cap from the small hose.
Hopefully this fixes it!
May 02, 2010 | LG WM-2277HW Front Load Washer
Oe message...filter is clean. water won't drain out. tub is ful
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Dec 21, 2009 | LG WM-2277HW Front Load Washer
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
Error Message/OE
sounds like too much water is coming into machine.check water valve,and water sensor.it is bringing in too much water or not enough.
Mar 06, 2009 | LG WM1814CW Front Load Washer
My Tromm washer blinks an OE message, the door will open, but the wash won't finish and there is water still in the washer. Please help
OE error means the water hasn't pumped out. 1st you need to check the filter behind the flap in the bottom corner. This may be blocked a check your outlet hose where it goes into the somethimes they get blocked there sometimes. When the filters out get a torch and shine it into the hole where the filter came from to see if theres a blockage in there. If all is clear will prob require a new pump.
Dec 20, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
OE message on our LG WM1832CW washer
I just was searching for the same exact error on my LG WM1832CW washer. From reading the other posts on different manufacturers I realized this was a pump clog issue for mine too. There is a small door near the bottom of the front of the washer and if you open that there is a filter basket. Once you start turning it and break the seal, the water will come out quickly, have 2 flat large tupperwares so you can catch the water. Once you clean out that filter it's good to go. A 5 minute job.
Jan 21, 2008 | LG WM0642H Front Load
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
