Question about Briggs & Stratton Garden
Trying to hook carburator back up and do not know were the throttle line or all the rods hook up at.
    President:
  • Briggs & Str... Master
  • 1,545 Answers
Check these diagrams for help. Without getting a repair manual, these are some of the better views available.
http://small-engines.com/bsgovernors.html
Posted on Apr 05, 2011
2009 V-Rod idles fine runs fine till heavy throotle let off and kills motor must turn off key and restarts fine
Hi Jeffpanshov, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Codes 1130cc com The 1 Harley Davidson Rod Forum
Dec 03, 2012 | Harley Davidson VRSCA V-Rod Motorcycles
Carburator removal partner k 750
Remove the covers and the air filter, the screw heads are Torq 27, with the covers removed, insert a Torq 27 tool through the small hole in the black air filter housing ( close to the back of the cylinder ) and undo the screw that goes into the cylinder, now grab the air filter housing and pull firmly toward the back of the machine, it will come away as an assembly along with the carb, lift up far enough to un clip the throttle rod from the trigger, un hook the fuel hose from the carb, you will now have the assembly away from the machine.
Jun 04, 2012 | Husqvarna Partner Gas Powered Cut Off Saw...
I have a Sears\Craftsman edger-eager 1 with a 3.8hp tecumseh motor. Recently I had to remove the carburator and of course didn't look to see where the linkage would attach back. Could someone pleae...
Look at the wear marks and dirt lines on the attaching plate. Once I got it messed up and now I take a picture with my phone before disconnecting anymore. If it is trying to throttle down instead of throttling up then you are on the wrong side of the shaft (pivot point).
I hope this helps get you going.
Aug 11, 2011 | Garden
Put a new carburator on and don't know how to hook
Hi janemueller...
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Free answer...Please take time to rate me
Jun 15, 2011 | Poulan Garden
I had to replace the gas tank on my stihl km 110r. After I replaced it the throttle is locked on high the moment I pull the start cord. It runs on nearly full power and then after a while starts to cut out...
the return spring on the carburator is come undone. this should be a light spring that pulls the butterfly closed and pulls against the wire from the throttle control and the arm that hooks the butterfly to the auto throttle advance. look for a loose spring and then make sure that both ends of the throttle control cable move and are hooked up. you should see the butterfly on the carb. move back and forth when you change throttle position.
May 04, 2011 | Garden
What connects the throttle linkage to the carburator? is it a spring or rod
It's actually a combination of both. There should be a small rod at one side of a small plate, (which acts like a cam) and a spring on the other side. The throttle cable pulls the plate and rod, expanding the spring at the same time. When the cable is relaxed the springs pulls the linkage back.
Mar 16, 2010 | Pool & Spa
Could some one tell us how the excelerator pump linkage on the float bowl side hooks up to the engine, that's a carburator for a 1968 chevy step van. the carburator is a rochester monjet # 7040021
Looking at an exploded view of your carburator in my Chilton book it would appear to me that the accelerator pump hooks to the throttle linkage on the opposite side from the throttle cable. On that end it shows a small plate that screws into the throttle shaft. This plate has 2 links attached to it, one of which should line up with a hole in the side of the main body. You will probably have to push the pump down by hand to line up the hole in the bottom of the pump arm with the hole in the body and attach the linkage.
There is no specific info in the book regarding this, just the diagram. Hope this helps.
Nov 11, 2009 | Chevrolet Chevy Cars & Trucks
95 chevy 350 TBI i installled new map sensor but the vacuum line was not hooked up, where does it go?
there is a port on the back of the throttle body, near the bottom, directly between the injectors.
Sep 04, 2009 | Metra 95 96 Chevy Truck
I need to know how to hook up linkage for throttle.
Take off the two scress that bind the throttle to the shaft, within the throttle you will see your cable at the hand lever end. The cable will slide out of a hole in the lever. The other end is attached to the carburator by a little ben in the wire. Use needlenose plyers to remove from the throttle body of the carburator, replace as dismantled. Your good to go.
Jul 05, 2009 | Garden
Throttle linkage for Poulan 1950le
Most times the thottle wire end is "Z' shape. The end of the wire is passed thru the carburator throttle lever untill the wire is past the first bend, the wire is laid over so that the travel of the wire is parallel to the swing of the throttle lever. Many times both end of the wire are the same or one end has a taller mid section to fit thru the hole in the plastic (if it's plastic) hand throttle end.
Jul 01, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
302 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
