Question about Sharp Office Equipment & Supplies
I have a Sharp EL-546D scientific calculator. I've hit some button and now there is an "H" on the left hand side of the screen and the keypad does not recognise a decimal point (if I type 22.11 it just enters as 2211).
    New Friend:
You have it in HEX mode. Hit 2ndF and then the + button. This will put it back into Decimal mode.
Posted on Jun 18, 2015
  • 3 Answers
SOURCE: Canon F-502 statistycal scientific calculator
As I added on to the previous solution on the other problem.
"Okay, I did what the best solution did and worked with it.
"1. press 2nd F (left top corner)
2. ENG/FIX (the button next to 2nd F)
3. press 0 (if you don't want calculator to round off any decimals)"
In order to get your exact value of pi, in step #3, instead of 0, press the decimal [ . ]
This should give you no decimals when entering a number and give you 3.141592654... when you input pi.
Hope that works/helps."
Posted on Nov 09, 2007
SOURCE: Sharp EL-5100 Manual
I've got a manual in the original box I got 30 yrs ago. The calculator's dial is getting to the unreadable state and I'm just about to turf it all out. Is there any particular function you want to know about?
Posted on Mar 11, 2008
  • 566 Answers
SOURCE: SETTINGS
Check the Decimal / Add Selector. It shoul be set to "A" (Add mode), to permit addition and subtraction of numbers without entry of the decimal point.
You may also want to download the SHARP
EL-1801P Operation Manual
Posted on Jul 25, 2009
  • 8023 Answers
SOURCE: Sharp EL-520R manual?
Here is the link to all supported educational calculators. Download the one closet to your yours. I looked under commercial, and consumer and no 520 listed.
http://www.lifechangingbox.com/products/TypeManuals/0,1083,15,00.html
Hope it helps.
Posted on Sep 19, 2009
SOURCE: Sharp ELSIMATE EL-240SA - how do you stop this
From the manual:
SETTING THE NUMBER OF DECIMAL DIGITS
Numbers of decimal digits of calculation results can be specified by pressing [C-CE] twice, then press [C-CE]and [M+] simultaneously.
The decimal digit assignment will appear as “F” (for “floating point”), “2” or “0” on the LCD. (The default is “F”.)
Press and hold [C-CE] and [M+] until the symbol changes.
Posted on Sep 29, 2009
How to plug in exponents on sharpe EL 501X calculator
Type in your base and then press the button that says y with an x as an exponent (last row of the small buttons, second from the left). and then type in your exponent.
Apr 09, 2014 | Sharp Shar El501xbwh El 501X Basic Science...
Have a sharp EL-506w calculator i have ten zeros on the screen it will do problems but it s a bunch of zeros behind it it aiso says x10 in small context at the far right side bottom of the screen.
Your calculator is set to display in scientific notation. To change it, press SETUP 1 then choose the desired mode. For most purposes you'll probably want Floating Point. For more details see the third column of the first page of the manual.
Oct 22, 2012 | Sharp Office Equipment & Supplies
How calculate degree in this calculator?
To set the angle unit to degree, you proceed as follows.
Open the MAIN calculator window (screen capture 1)
Tap the down pointing arrow at the left (Left of Edit)
Tap the Geometry Format to open the next window. If the second drop down
window (Angle) does not display Degree, tap the small arrow at the right.
Highlight degree and press the Set button at the bottom. If you want degree
to be the default angle measure, tap the Default button
k24674_2.png k24674_3.png a
Sep 03, 2011 | Casio ClassPad 300 Calculator
Where is the fraction button for sharp el-738 ? thank you
The EL-738 doesn't have a fraction mode like some other Sharp calculators.
Feb 02, 2011 | Sharp EL-738 Scientific Calculator
Where is the button for fractions on the Sharp EL-738 calculator?
Jan 17, 2011 | Sharp EL-738 Scientific Calculator
Where is the clear button? if i want to clear everything to "0"
It is a 2 step button push * at the bottom left the hit CE Not any manual that I could find. It works
Dec 13, 2010 | Sharp EL-2196BL Calculator
How to add decimal on SHARP EL735S
how do i increase decimal places on a sharp el735?
Jun 02, 2010 | Sharp EL-738 Scientific Calculator
Setting tax
If the model is EL-2125 , and not 2125C or 2125E the following will work
1)switch on
2)press CE and then CA (you should see 0. with small 00 in top left hand corner but nothing else)
3)press M- button (rate set button),current tax rate 17.50% will appear with tax at left hand side
4) type new rate eg 15.00 (making sure to hit the decimal and two zeros, tax at the left and % should still be on the screen)
5) press M- (rate set button) (small 00 will appear in top left hand corner)
6) press = ( new rate and G will appear small 02 in top left hand corner and = sign below it)
hope this works for you, please let me know either way
David
Jul 31, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
440 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
