Question about Samsung Washing Machines
I have a samsung frt load washer wf206BNW/XAA. It vibrates and shakes the whole floor during high spin and makes a thumping noise. I checked level and it seems OK. All pads are on floor. It does this with big or small loads. Any suggestions? Could the shocks be worn out? (It is used often - 3 kids, heavy loads).
  • jim23456789 Apr 12, 2011
    John,
    I re-re-re leveled and it didn't help. What do you mean internal suspension is malfunctioning? Worn out shock? Or how would you troubleshoot?
    Brigadier General:
  • 6,277 Answers
Although you say it's level I really would recommend you try my method to make absolutely certain before considering something inside ;-0)
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly!
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Apr 05, 2011
  • 1 more comment
  • john_cross Apr 12, 2011
    Hi Jim,
    Yes- suspension is normally by springs and shocks but with a big slab of concrete on top of the drum. If you want to attempt to fix yourself take the back off- with power off of course- and you should be able to tell first by looking at the slab which should be in one piece, then by rocking the drum and listening to and watching the springs and shocks. If you feel up to it keep the back off and run a spin with garments in the washer- with the washer 'still' level/balanced. If you are not comfortable investigating then you will have to call for an engineer/serviceman.
    Hope this helps and good luck,
    John C
    Thanks John. I don't see any concrete "slab" - it is a direct drive unit, and everything is very intact. I didn't bother to run it with the back off - that is a great idea. (A pain to do in my small room - but a good idea).
    The one thing I do notice is that the shocks seem to offer almost no resistance - so I have ordered a new pair. We'll see how that goes... Any other advice would be greatly appreciated.
    Thanks
    Jim
  • samAUSTRALIA Apr 08, 2013
    Hi Jim, did new shocks feel like they offered more resistance? Did they solve your problem?
Samsung washing machine wobbles on spin.
The feet of the machine have to to be leveled. When reading the instructions, leveling is important for the very reason you are having difficulties.
Sep 19, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Washing machine shakes violently during spin
Hi
If your washing machine shakes violently or if there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Also check this link bellow:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
May 03, 2011 | KitchenAid Washing Machines
Whirlpool design 2000 is imbalanced eery load - moves around violently, makes pounding noises.
Thanks for choosing FixYa and welcome. You need to check the suspension of the washer and make sure everything is intact. Now, if the washer is thumping during spinning, this is probably the motor drive or the spin bearing. This would cause a lot of noise. Your washer will act up if it is not balanced right. Check the floor and make sure it is level. If that checks out, look into the motor drive and bearings. The motor drive controls the spinning.
Apr 28, 2011 | Whirlpool Washing Machines
Excessive shaking on spining , washer moves a round on the floor I have leveled it rght on the nose.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 18, 2011 | Kenmore 44042 Front Load Washer
Vibrates, shakes and moves around and has a lot of noise while spinning. It has been leveled and the floor seems sturdy enough.
Washer Problems Washer noise when spinning
heatman101
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
4 month old washer is so loud it sounds like someone dropping a trash can to the pavement from 5 feet high
Check to make sure it's level. Number one cause of vibration is not being level. Number two cause is soft floor and what I call "Sympathetic vibration" where the floor shakes a bit and it seems like it's in time with the vibration on the washer. It then magnifies the vibration and makes it worse.
If it's level and on a solid floor, you need to get it serviced under warrenty.
Feb 22, 2010 | GE WSXH208A Front Load Washer
I have a zanussi washer/dryer but lately its making so much noise !! its driving me nuts please tell me what it could be ?? thanks
Hi
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
Bellows
The bellows is a rubber sleeve that seals the suspended outer tub to the stationary cabinet front at the tub opening. Its purpose is to provide a water tight opening into the tub that can be sealed by the cabinet door, yet allow flexibility for the oscillation of the tub during the wash and spin cycles.
Outer Tub Assembly
The outer tub assembly is supported by two suspension springs and stabilized by two air shock assemblies. A cement counter weight is mounted to the front of the outer tub by screws. A counterweight is molded into the rear half of the outer tub. These counterweights prevent excessive oscillation of the entire suspended assembly during an unbalanced spin cycle.
Spin Basket Assembly
The spin basket is constructed of stainless steel. The circumference of the basket is perforated to allow water to flow through it as it revolves. A heavy steel shaft is pressed into the spin basket support which is then bolted to the basket. The spin basket assembly is entirely supported by two ball bearings pressed into the rear of the outer tub. A large drive pulley is mounted to the free end of the shaft that extends through the rear of the outer tub. There are three plastic vanes mounted to the spin basket to aid in the washing action during the wash cycle. The rotation of the spin basket provides both the washing action during the wash cycle, and water extraction during the spin cycle.
High pitch "jet engine" noise--A certain amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in drum or pump. Stop washer and check drum. If noise continues after washer is restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To prevent unnecessary noise and damage to drum, fasten fasteners and turn items inside out.
Squealing sound or hot rubber odor-- Washer is overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a thumping sound. This is usually normal. If sound continues, washer is probably out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for details.
• Shipping bolts and foam blocks have not been removed during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
Washer appears to be out of balance
Double check the screws holding the washer to the pedestal to make sure they are tight and make sure all the jam nuts on the leveling legs are tight. Loose jam nuts are the most common cause of this.
If they are tight, loosen the right front leg and screw it up until the weight is off the floor. Then run it back down until it contacts the floor. Put the washer in high spin and tighten it down to the floor until you get the spot where there is the least vibration. Tighten jam nut, and check it again in spin with a load of clothes.
Post back and let me know how this works.
Oct 18, 2007 | Whirlpool GHW9100L Front Load Washer
Washing Machines Logo
214 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
