Question about Samsung Refrigerators
Hello, I bought the Samsung frige, Model of RS2555,nearly 3 years ago. It has been working very well so far but from a few days ago water is not comming out. Before the same thing happened several times, but one or two days later, the water was coming norally. But at this time already one week have passed since it failed. I tried to fix it by unpluging for 12 hours and reset. But it does not work. I confirm that the water is in the water filter, I think something wrong on the water line in fridge, looks like freezing of line? Can you give me how to fix it? Thanks for your help.
  • 2,427 Answers
Well if the lines freezing , the only thing that can cause that is low freon. Meaning there is a leak on the line. Do you have gauges, dyes and the other stuff needed ??
  1. connect gauge to refill port and check freon pressure it should be low.
  2. remove gauge, inject gas dye and inspect the lines to look for signs of the dye this should tell is if there is a leak. if you find the leak, mark it with a marker, remove dye injector, and let the pressure settle. solder the leak closed. if there was no leak then your set.
  3. top up the freon, connect the gauge, connect the tank to gauge, gauge in the freon, and your done.
now if you don't have the above equipment don't go and buy any, its cheaper to call in a repair man. Let me know if you need more help!
Posted on Apr 06, 2011
HELLO I BOUGHT A 60 INCH SAMSUNG SMART TV ESUN8000, 6 MONTHS AGO, AND I NOTICE THAT IT HAS 3 WHITE DOTS. WHAT CAN BE THE CAUSE OF THE PROBLEM? I BOUGHT THE TV AT BEST BUY, DO YOU THINK THAT THEY CAN H
sound like you have samsungs dlp white spots plague, which just gets worst. samsung are aware of the problem, so you need to get in touch under the warranty.
Nov 25, 2013 | Sony KDF-42WE655 Television
Coleman 3 way refrigerator does not keep cool temperature
I would guess you have a refrigerant leak if I understand you. Have this guy pull a vacuum on the system and see if you lose the vacuum.
May 18, 2013 | Cars & Trucks
Hello I bought a Samsung tv about 2-3 years ago and I have the serial #, model # and I am trying to find the value of the tv bc it had been damaged by the shipping company
It will be based on current value of the same size or comparable TV made now. The TV's usually cost less now then they did a few years ago and yet usually do more. Their insurance company will set a value and in the mean time price new sets with basically the same features
Jul 29, 2011 | Samsung Televison & Video
I have got olympus digital camera model FE-230 purchased in 2007. few days back my camera got switched off while using. till then its not geting switched on. what might be the cause. plz assist me. ...
Have you tried checking the battery? As you mentioned before, the camera was bought 3 years ago. And doesn't specify if you left the batteries inside the camera. Please try replacing the battery, otherwise send the camera to the nearest Olympus for technical check up.
Thank you
Aug 07, 2010 | Cameras
Frige freezing solid
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Problem with MP3 player
I bought a few mp3 players that had same problem. Couldn't figure it out. They were nextar too. I don't buy them anymore. Nextar are really cheaply made. I would suggest taking it back, buying higher quality name brands. Creative is a higher quality, cheap and lasts a long time. Use mine everyday, has lasted 3 years so far.
Dec 11, 2008 | Nextar MA933A MP3 Player
Samsung RS263BBWP Side by Side Fridge: Water line continually freezes
higher numbers on the tempature set make the fridge
colder lower numbers make wormer
May 23, 2008 | Samsung RS2556 Side by Side Refrigerator
MAH3000AWW
Replace both the main control board and the wax motor. This sounds like a computer chip malfunction
As far as the squeak, make sure it is not the bearing located at the back of the tub under the large pulley.
Jan 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Refrigerators Logo
119 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
