Question about Primera Technology Bravo II AutoPrinter InkJet Label
I am running a Bravo XRP with PT Publisher. I have tried several ways to get the printer to use B&W ink and it will only use the color cartridges. Our company is printing primarily black on a white disc with a small blue company logo. I set the ink settings to B&C; the color matching setting is on 'graphics'; Disc surface Quality = 'high' (which it defaulted to after I set it to 'Medium') and ink saturation is set to 100. Michael
edisonfrelan
  • 113 Answers
SOURCE: Primera Bravo CD/DVD printer -- prints blank
Let the printer repair itself. Got to start menu select the printer then select properties. Go to maintenance menu try all the basic testing. If it still didn't work out, delete the previous driver and install it again, then restart and try printing again.
Posted on Dec 14, 2008
  • 6 Answers
SOURCE: i can,t print
this usually indicates there is a problem with the cartridge, check the bottom of each cartridge and see if the colour barcodes are intact and ensure you are not trying to start the machine with the lid up as too much light coming in will also cause the problem when reading the coloured barcodes on the bottom of each cartridge
Posted on Feb 17, 2009
  • 15 Answers
SOURCE: Similar pick up and drop problem
Try reinstalling the drivers. Does the printer tray retract?
Posted on Aug 25, 2009
  • 7 Answers
SOURCE: Primera Bravo Pro grabs 2 discs frequently
Hi I use to bye verbatim in 50pcs cackebox then there is no problem... when i bye cheep discs and in 100 or 200 spindels i also some times get problems..
Posted on Aug 29, 2009
jomabug76
  • 1148 Answers
SOURCE: I have a Bravo SE printer at work, but when ever I
be sure to not only print an alignment page but do the head cleaning options on printer tools/properties,,should help,,or even correct ur problem
Posted on Nov 08, 2010
Testimonial: "Thanks, it didn't fix it, but the print that way looked perfect so I knew it was a setting issue. I changed some settings and it looks fine now :)"
When I print the Black ink does not print on page at all. All of the colors cyan, magenta and yellow are fine. I haver replaced the Black Cartrige and Run the printers cleaning cycle several times.
maybe you run out of ink for black, try to use other ink, if its still the same then their a stockup ink on your head of the printer and better to replace it. I think once you purchase an ink cartridge of cannon their is also printer head included. Hope it helps thanks.
Sep 19, 2011 | Brother MFC 490cw Color Inkjet...
I have a HP 1460 printer & I have now no black ink in my printer.can this printer support any duplicate cartaige(local cartaige)?
No, that printer only uses the 21 Black and 22 color cartridges. The best thing to do when you run out of ink is to buy a refill kit and then refill each cartridge at home. This saves lots of money in the long run. Click on the link below to view a refill kit for your HP D1460:
http://cgi.ebay.com/Refill-ink-HP-21-Deskjet-1420-1430-1460-BK-4oz-s-/320621581336?pt=BI_Toner&hash=item4aa6891418
Feb 13, 2011 | HP DeskJet D1460 InkJet Printer
BRAVO PRIMERA 11 ERROR CD PUBLISHER
The Publisher has a cartridge problem. Check to make certain that the cartridges are installed correctly and that the bar code labels on the underside of the cartridge are not damaged.
Jul 13, 2009 | Primera Technology Bravo 2 Disc...
Incorrect & missing colors
I would try purchasing new ink - especially if the printer and inks has been sitting unused.
May 14, 2009 | Laser 3115cn All-In-One Printer
Hiya how do i check the inks on my bravo 2 primera
Go into your printer driver; ie. control panel -> printers and right click the CD/DVD printer. Press "Printing Preferences" near the bottom of the Properties window. Click on "Clean/Change cartrdiges & check Ink" and select properties.
Mar 05, 2009 | Primera Technology Bravo II AutoPrinter...
My printer will not print text.
Did you try and change the ink cartridge mode from color + black to color, or vice versa? Another thing you can try is to "prime" the ink cartidges by taking them out of the printer and gently pressing on the print nossels to get the ink flowing, then put the cartridges back in the printer.
http://www.techwaredist.com/repairshop.asp
Dec 09, 2008 | Primera Technology Bravo II DVD Duplicator...
The disc arm for the bravo disc publisher primera is telling me that the disc was not picked up, and to press the left button on the machine to try again. I have done this plus I have turned off both my...
hi,
i think you already need to clean your equipment.
this is part of the manual of your equipment and follow their tips to prevent damage.
go to this link: http://www.primera.com/manuals.html
to download the files.
Section 5: Maintenance and Troubleshooting
A. INTERPRETING THE PUBLISHER’S INDICATOR LIGHTS
The Power/Ink button can tell you what is happening inside
the Publisher. Please refer to the following:
Power/Ink Button Publisher
Fast Flashing The Publisher is initializing.You will see this
pattern when the Publisher is first turned on.
Wait until the lights stop blinking before
opening software or starting jobs.
Slow Flashing The cover is open and the ink cartridge carrier
is in change position. Insert a new cartridge
and close the cover. (The slow flashing light
can also indicate an out of media condition,
a robotic error or a picking problem. However,
these conditions are always paired with a error
message on screen.)
B. CLEANING THE PUBLISHER
NOTE: Do NOT attempt to oil or grease the Publisher's Robotic Arm shaft
or other components. You will likely cause more harm than good!
Any moving parts are designed to operate for the life of the machine
with no additional lubrication required.
Use a clean, lint-free rag with a small amount of ammonia
window cleaner to clean the Publisher's outside case and
trays. This type of cleaner is very effective on inks that may
accumulate on the printer tray. Stronger cleaning solutions are
NOT recommended because they may damage the paint and
plastic materials from which the parts are manufactured.
Always disconnect your Publisher's power cords before
cleaning. Resume operation only after the surfaces are
completely dry.
C. PERFORMING A ROBOTIC SELF-TEST
To ensure that everything is working properly, a Self-Test
feature is built in to your Publisher. In this mode, the Robotic
Disc Transporter will go through the motions of picking and
placing a disc to ensure proper working order. This test may be
performed without connecting the Publisher to the PC.
Perform the test by doing the following steps:
• Load some discs into the Input Bin.
• Open the cover.
• Press and hold the power button for five seconds. The test
will start.
• To stop the test, close the cover and press the power
button.
D. CLEANING THE INK CARTRIDGE
It may be necessary to clean the ink cartridge nozzles if you
notice reduced print quality, or if you suspect an cartridge nozzle
has become slightly dried out or clogged. If you are having
print quality problems, follow the steps below:
1. Remove the print cartridge.
2. Moisten a lint-free cloth with water.
3. Hold the cloth against the
nozzles for three seconds.
This will “wick” some
additional ink onto the damp
cloth.
4. Wipe in one direction only.
5. Repeat the process
E. TECHNICAL SUPPORT
If you have difficulties in operating your Publisher, the
procedures in this manual and the software User's Guide
should, in most cases, solve the problem. If you still have
difficulty, contact the technical support number listed on the
insert included in the supply pack that came with your
Publisher.
Source Location
Primera Knowledge Base www.primera.com/knowledgebase.html
PTPublisher Software Help files Open the software. Click on the ? icon in the
upper right corner of any screen.
SureThing Software Help files Open the software. Click on the Help
Menu - Contents
Email Support www.primera.com/contact_tech_support.cfm
Chat Support www.primera.com/knowledgebase.html
Phone Support 763-475-6669 (Mon - Fri 8 a.m. - 7 p.m. CST)
Nov 22, 2008 | Bravo Computers & Internet
Printer has completely quit printing color with new ink installed
In order to determine whether this is a hardware or software problem there are several steps you can take:
1.Download and install the most recent printer driver from Epson
2. Try printing out the nozzle check pattern using the Maintenance Utility. This bypasses the printer driver and allows the printer to use all cartridges to print out the patterns. This will indicate whether there are clogged heads and whether or not it will print color at all. Gaps in the patterns indicate clogged heads and you need to run the Head Cleaning utility once or several times.
3. If you get color patterns from the nozzle check (whether or not the patterns are full or have parts missing) you need to check to see if the default settings for the printer have been set to "Black Ink Only". Right click on the printer icon and select "Printing Preferences". Click on the "Advanced" button in the lower right corner and after the popup, look on the left side and see it the "Black Ink Only" box is checked. If so, uncheck it and while you are there uncheck the "High Speed" box as well. This way you don't have to deselect it in the printer dialog each time you print, especially if you are looking for a quality print each time.
4. Try the printer on another computer if you get color during the nozzle check to see if the software is corrupt on your computer.
5. If you get no color patterns at all when doing the nozzle check, it would appear that you have a hardware problem within the printer. It would be unlikely that all the colors would fail at the same time due to severe head clogging.
Hope this helps in some way.
Oct 07, 2008 | Epson Stylus C86 InkJet Printer
Out of ink message when don't use color printing much
Try to run the cleaning procedure several timesuntil the problem is gone, but be aware that it will consume ink from all cartridges.
Generally:
It is better to print from time to time pages using all ink cartridges otherwise the printhead might be damaged. You also might run the cleaning procedure of your MP500 from time to time.
Both will consume ink but letting it dry-out will cost at least the same.
Aug 28, 2008 | Canon Pixma MP500 All-In-One InkJet...
Primera Technology Bravo II AutoPrinter InkJet Label Logo
116 people viewed this question
Top Primera Technology Office Equipment & Supplies Experts
Josh Whitehead
Josh Whitehead
Guy Loeffler
Guy Loeffler
Level 1 Expert
Martyn01202
Martyn01202
Are you a Primera Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
