Question about Fellowes 220 Powershred Strip-Cut Shredder
The shredder will not automatically shut off. After you have finished feeding the documents to be shreeded the machine contunues to run and you must manuall shut it off.
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 99 Answers
Depending on what you have available, either a damp paper towel or alcohol wipe, or compressed air will work to clean the sensor eye located top at the center of the paper feed opening, you should see a little dot wipe, or spray these out well, then turn the machine off and back on again.
built up dust from the paper causes the sensor to keep registering that there is paper coming in hence it won't stop on its own.
Posted on Oct 30, 2011
Wont automatically feed paper to shred
there is a small switch or an infra-red sensor that sees the paper. Check it in the slot of the shredder.
Paper Shredder Parts
shredderparts.com/
We sell all sizes of paper shredder gears, switches, blades, etc. to facilitate your repair. We also have shredder replacement parts for crosscut paper shredders, ...
General Shredder Parts - Shredder Repair Services
www.shredderrepair.co.uk/general-shredder-parts-227-c.asp We can supply a wide selection of parts for various makes of shredder some of the ... Paper Shredders ... Please note SRS take no responsibility for loss, damage or personal injury caused by the fitting of spare parts by non SRS personnel.
Paper Shredder Parts ' All brands inc Fellowes & Rexel » Document ...
https://www.documentdynamix.com.au/service/paper-shredder-parts/ Document Dynamix Australia has a strong reputation for responsive supply of paper shredder replacement spare parts and support. Whatever brand your paper ...
Jul 17, 2017 | Cars & Trucks
Does not auto shut-off anymore?
Automatic feed switch jamed with paper. reverse and forward several times may help. Otherwise turn it over and pull paper out of the bottoms to clear the switch jam.
Apr 06, 2015 | Cross Executive EPS-1501X Shredder
Won t shut off
Blow out the sensors with some compressed air, Using a can of compressed air, look for the sensors that detect the paper and give them a blast or two, then try it, it may take a couple of tries.
This may also be a good time to lubricate the cutting heads, if it is a good machine with metal heads a light oil applied to paper then run through the shredder will pass the oil onto the heads.
A shredder oil or light oil like 3 in 1, these usually have a narrow nozzle to limit the oil flow, draw lines, do a picture or spell your name on the paper with oil and shred it. You have just serviced your shredder.
If it is a less expensive shredder with plastic heads, shredding a couple if sheets of waxed paper will pass the wax onto the cutting heads reducing friction.
Hope this helps.
Ed
Oct 01, 2013 | Office Equipment & Supplies
DM12C no longer automatically shut off
there is a photo eye down inside the paper slot. when you put the paper in it trips the sensor. this sensor get covered up with fine paper clippings unplug machine and take some compressed air or maybe a q-tip and clean the sensor. should be two right across from each other
hope this helps
Jul 26, 2012 | Fellowes DM12C Shredder
Whenever I sred a document the Shedder keeps running and does not automatically stop when the document has been sredded. Is this a fault or can it be rectified?
If the shredder has "eyes" where you insert the paper try cleaning them with a soft cloth( Unplug machine first.) If that does not fix it then most likely the pcb inside has gone defective....phone supplier to get replacement parts and prices.
Aug 12, 2010 | Fellowes Powershred C-220 Strip-Cut...
HSM AMA 125HS-6 Starts to shreed and abuptly stops. Red light comes on next to a circl symbol.
Thickness of papers is too much. Feed only 1-2 pages at a time.
To clear, pull paper back out. Run reverse, then forward, then feed 1 page at a time using a clean edge.
Sep 13, 2009 | Office Equipment & Supplies
Was shreeding paper and it stopped? cleand it. thought it might be over heated. compucessery mo.#ccs60061. Its new. Thanks Mark
some of the new shredders do that so you should get a shredder that has a warrenty so if this happens again you dont have to worry about haveing to buying or fixing the shredder because when you try to fix these type of machines you ether end up just causing the machine to be comepletly unusable or it works of a little wile and u have to try to fix it again instead i advise you buy a replacement Fellowes® PS-79Ci doesnt jam and can dice 12 sheets of paper
hope this helps
Jul 31, 2009 | Compucessory Office Equipment & Supplies
Shredder won't stop after shredding
Blow out the electric eye in the feed slot with compressed air.
Jun 28, 2009 | Office Equipment & Supplies
Will not shreed over load light come on.
My guess is their is a build-up of shreds in the cutter shroud that is binding the assembly. Need to take it apart and clean.
May 01, 2009 | Office Equipment & Supplies
Fellowes 220 Powershred Strip-Cut Shredder  Logo
440 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
