Question about RCA Universal Remote Control
I have a jensen surf series sc330. How do I set it up to my tv?
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): I have a jensen surf - clip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
SOURCE:
I need the TV code for the remote for Jensen TV model number JE2608WV
2285,2261,2290. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 12, 2015 | Jensen Televison & Video
How do I get codes from jensen universal remote control to operate a sharp tv.
0281,0288. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
Oct 17, 2014 | Jensen Televison & Video
What is the remote code for Jensen 27" LED TV
0028,0022. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
Oct 11, 2014 | Jensen TS2750J TV
What is the the code for a Jensen tv for a RCA Universal Remote
0247 0369 0379 0460 0642. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
Sep 28, 2014 | RCA Universal Remote Control
Are there any instruction manuals for a Jensen SC330 remote control?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Aug 23, 2014 | Televison & Video
Mirai codes
260,266,268. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls. Surf the sites with patience.
Jan 25, 2014 | Jensen TS2750J TV
Hi, I lost my code list, I have a daewod tv, I need the code for my tv, my model contol is jer321 thnks a lot
Hi
Codes to check with Daewoo TV with Jensen 300 series remote control are;
477 / 473 / 468 / 465 / 459 / 455 / 453 & 414
OK.
Jul 24, 2011 | Jensen 143307 Remote Control
Unable to recode my jensen surf series sc330 universal tv remote control
Hi awaiting,
You should be able to use a search engine with the keywords:
Jensen sc330 Codes
It appears to be a number of websites that have digital copies of the codes.
Sincerely
Agent Jon
Go Ahead. Use Us.
Apr 15, 2008 | Televison & Video
Remote code orion tv/vcr # tvcr0950bw
I have an Orion TV/VCR combo with a Philis Universal remote. I had to use the Sansui codes for the combo. My code for my Orion was 632.
Dec 06, 2007 | Orion1934 19" TV
Televison & Video Logo
99 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
