Question about HP Office Equipment & Supplies
My HP Laserjet 2300 will not start up correctly. The ready, data and attention lights flash and the screen only shows the alternating HP logos after the initially memory countdown. I can get the printer to finally go through the entire initialization process by doing a cold restart. But if the printer goes to sleep or needs to be restarted, I have to repeat the cold restart each time. Any words of wisdom would be appreciated.
  • 298 Answers
SOURCE: DIMM Error HP P3005n
Link to HP P3005n manual
read pages 183 thru 187
speciial attention to p187...
1. Turn the device on. Check that the Ready light is illuminated after the device has gone through the
startup sequence. If an error message appears, a DIMM might have been incorrectly installed.
See Control-panel messages.
Click on control panel messages to go to Control Panel Messages
Posted on Dec 13, 2007
headstrong
  • 233 Answers
SOURCE: hp laserjet 1200 printer problem
press the big button for secondary light pattern error code
most likely you have a bad fuser
thanks for rating
Posted on Jan 14, 2008
techguru005
  • 28 Answers
SOURCE: HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Posted on Feb 22, 2008
  • 313 Answers
SOURCE: switch on the hp laserjet 1160, The Attention,
you may have a fetal error, press the button to see the secondary error code
Posted on Apr 06, 2010
  • 8 Answers
SOURCE: problem with p4014n laserjet printer
firmware
Posted on May 19, 2010
Printer 5550 laser color cood 59.c0
I am assuming you meant HP Color LaserJet 5550 Error Code 59.c0
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Sep 06, 2016 | Laser Office Equipment & Supplies
Error Code 51.2 C on an HP 4600
This is a laser error. I found this directly from HP's website. Here's your fix:
  • Press the green c00224695.jpg (Select) button to continue.
  • Turn the printer off, and turn it on again.
  • Perform a cold reset.
    1. Turn on the printer.
    3. When the memory starts counting, press and hold the c00224695.jpg (Select) button.
    4. Continue holding the c00224695.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the c00224695.jpg (Select) button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  • If this message persists, contact an HP-authorized service or support provider. Please let me know if this helps you!
  • Oct 01, 2011 | HP LaserJet 4600 Printer
    My HP laser jet 4250n printer turns on but the display screen is blank --there is no message. the ready light, data light and attention light all come on
    Could be bad Control Panel or bad Formatter.Start with the Control Panel, it's cheaper.1st make sure the cable is attached to it.
    Sep 29, 2011 | HP LaserJet 4250n Printer
    Out laser 2300 printer has ready, data and attention lights flashing and we cannot get anything to prine- we have tried cold reset and other suggestions and nothing seems to correct our problem- any...
    All three lights flashing indicates a general failure. this is caused by either a bad connection, a bad formatter or a bad engine control board. Disconnect any cables you have attached to the printer and restart. If it starts fine then you may have a bad cable. If this is a networked printer, then it is quite possible that the network card has failed. You can try removing the network card if it has one and restarting. The JetDirect 615N card that shipped with this series of printers is notorious for failures.
    Sep 06, 2011 | HP LaserJet 2300d Printer
    Code ereur 59
    A code error 59:
    Description A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly. Action
    1. Press the green c00099346.jpg (Select) button to continue.
      3. When the memory starts counting, press and hold the green c00099346.jpg (Select) button.
      4. Continue holding the green c00099346.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
      6. Press c00099347.jpg (Down Arrow) button once. The control panel will display COLD RESET.
      7. Press c00099346.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
    Mar 02, 2011 | HP LaserJet 5550DN Printer
    Error 51.2 y hp color laserjet 4600
    Hi There, Please follow the below steps to fix this issue :
    Action : 1. Press the green (Select) button to continue. 2. Turn the printer off, and turn it on again.
    3. Perform a cold reset : a.Turn on the printer. b.Watch the control panel. c.When the memory starts counting, press and hold the (Select) button. d.Continue holding the (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady. e.Release the (Select) button when the Ready, Data, and Attention light are on steady. f.The control panel will display SELECT LANGUAGE . g.Press (Down Arrow) button once. The control panel will display COLD RESET . h. Press (Select). The printer will perform a cold reset and then continue its power-on sequence. 4. If this message persists, contact an HP-authorized service or support provider.
    Nov 08, 2010 | HP LaserJet 4600dn Color Printer
    Blue light flashing light, red light on
    The flashing means that the toner and/or the imaging drum is empty or missing (printing halts on these errors). Lights on steady means low toner.
    Jun 24, 2009 | HP LaserJet 2550n Printer
    HP Laserjet 1012
    You need to print the configuration page :
    => Power on the printer and makes sure it comes to the 'Ready' state.
    => Press and hold the Go button between 5 and 10 seconds until the attention and ready lights flash.
    => Release the button. If you held the button down for too long it would flash the Attention LED.
    => Press and release the Job cancel button to start all over again if you held the button down for too long.
    Sep 22, 2008 | HP LaserJet 1012 Printer
    Error
    ● Manual feed
    specified tray
    error
    Solution
    completes the job.
    Feb 05, 2008 | HP LaserJet 1320 Printer
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
