Question about Samsung Microwave Ovens
Wiring diagram required for Samsung hob mdel CT1613GIN
  • Brian Manuel Apr 05, 2011
    Unless you know what you are doing ,I would stay away from fixing microwave ovens . They are very high voltage and have a chance of radiation . So if you know what you are doing ok ; but its not worth getting hurt.
I have a Defy Gemini Petit Chef oven and glass hob combo. On e plate on the hob appears to heat up to maximum temp irrespective of the setting on the control. The other plates seem to be fine. Is there...
If it is a "Hot Plate" then the thermister is probably within the plate and replacement of the plate may be required.
Call a qualified appliance repair person for an estimate of the cost to repair.
Mar 23, 2011 | Microwave Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
Can I gaet a new glass top for a Diplomat HJA 1613 ceramic hob?
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 05, 2011 | Bosch Microwave Ovens
Replacement ceramic hob element C00228943 for Creda EDCW60 has 4 connections on thermostat in place of 2 on old unit. Do you have circuit diagram for this replacement element please?
Sounds like it is the wrong element. I wouldn't like to advise further without seing it. Contact your supplier and ask for an explanation.
Dec 24, 2010 | Panasonic NN-P794SF Microwave Oven
Good morning We are about to fit a rangemaster classic hood 120cm approx. to suit our Elan 110 dual fuel cooker with a gas hob. What is the corrrect distance we should leave between the hob and...
In my experience, the hood should be just above head height, that will avoid banging your head, and at least 33 inches or 8ocm above the hob.
Hope this helps.
Nov 03, 2010 | Microwave Ovens
I got a faber 4 burner hob for my under constuction apartment. my technician told me that he will cut out a rectangle(of required dimension) from the granite counter top .my worry is that when this piece...
You will be fine. No heat will be generated under the unit. The units are designed to be supported around the rim, usually only about 1/4" is required.
Oct 16, 2010 | Microwave Ovens
I need to replace the Sumsung Microwave Oven Mdel: SMH7185STG. The part is availoble but there are no screws visible. Need instructions on how to replce the door handle.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 02, 2010 | Samsung Microwave Ovens
Microwave Ovens Logo
115 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
