Question about Brinkmann 5 Burner with Smoker 8101750S
Seems like burners flames dont get big - Brinkmann 5 Burner with Smoker 8101750S
    Brigadier General:
  • 4,736 Answers
Paula, you're propane tank may be almost empty or the OPD Valve in the tank has locked up your grill regulator. To test this theory, turn the propane tank valve OFF and disconnect the hose. Wait 5 minutes and reconnect the hose. Turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow). Once it's completely open, light the burner farthest from the tank first and turn it to high. Does the flame height appear to be normal? If so, light the remaining burner(s) the same way. If all the flame heights are now normal, you solved the problem Just remember to alway trun the tank valve ON very very slowly. If that didn't solve the problem, you need to replace the grills regulator/hose assembly. You can purchase it at any home center or hardware store that sells gas grills and accessories. Just take your old one wih you for comparison purposes.
Hope this helped you to get back up and grilling!
Posted on Apr 05, 2011
Why my cooking range big burner giving yellow flame whereas other burners running.
A yellow flame indicates not enough air is reaching the burner. That particular burner may have a clog which is preventing sufficient air.
May 18, 2014 | Ovens
Burning smell from underneath the bottom oven plate
Something spilled into the area where the flame is Those big gaps in the bottom plate is how the heat gets into the oven from the burner . Try letting the oven burn off whatever spilled in it
Jan 04, 2014 | Samsung FX510BGS Gas Ranges
I light the first burner and the flame doesnt seem as big as it should be, I light the second burner and the flame goes down slightly, I light the third burner and it goes out completely
clean all the burners and the orffices , check the gas is full if lpg ,check gas line is not blocked , if this natgas grill check connection is in tight and not loose giving small flow of gas.
Aug 28, 2011 | Grilling
My ge gas stove works, but the flames just don't seem big enough. even on high, it takes forever to bring a covered pot of water to a boil. The flames seem even, mostly blue with some orange/yellow. any...
There can be poor air mix ( oxygen) for the flame to grow up. so remove the burner and use a good metal brush and air jet to clean off allt he crust and dirt of food lodged into the burners.
Now if the regulator gas fflow is down then your jet is blocked. If so you might have to remvoe the regulator to see that the jet is cleaned out . use a thin pin and airjet to clean.
Sep 16, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Not enough gas/flame.
You probably have water in the burners. If you can get one burner to light, let it warm up the grill and maybe it will dry out the others.
Apr 07, 2010 | Char-Broil Advantage 463453306
Back burner makes periodic clicking noise and flames increase
This clicking noise would be an indication that the burner is 'burnt out'. Burners have individual ports that release individual flames to create one big flame.
If the burner has a hole in it or the burner's internal baffles are burnt out the burner will make a 'popping' or 'clicking' noise.
Also, heat makes metals expand and when metal expands it makes a clicking noise. The increase in flame could be because the burner has a large hole in it or the holes are increasing in size as they expand, thus throwing a larger flame.
Just a thought.
Ben Gaetani
Tanks 2 You Propane
propanetanks2you.com
Mar 20, 2010 | Weber Genesis Silver B Grill
LP gas conversion oven flame to big
I did all this and the flames are still huge inside the oven...
May 27, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Aug 01, 2008 | GE 36 in. JGP628 Gas Cooktop
Brinkmann 5 Burner with Smoker 8101750S Logo
171 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Lyle Siemens
Lyle Siemens
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
