Question about Dayton 1DGX6 Dehumidifier
We have a Dayton 5EAJ9 dehumidifer in our work office. It continuously runs and will change to turbo.. it is so loud and is set at 30%. What should it be set at and HOW CAN WE CHANGE THE SETTING? We have tried everything. Isn't 30% too low?
GE dehumidifer fan making loud knocking noise
possibly have to take motor and fan out as a unit to get fan off .
Sep 19, 2015 | General Electric AHH40LH Dehumidifier
What is the P1 code on my Dayton Dehumidifier 5eaj9 mean?
Empty the bucket. Reseat the bucket carefully or the code will not reset. This is the only documented action for code P1.
Jun 14, 2014 | Dehumidifiers
Humidity sensor
It may be right. Are you sure you need dehumidification?
Put a free-standing humidity meter near the unit to check.
If you still want to run the dehum, take the humidity sensor out of the line and control the unit with a timer.
Aug 17, 2017 | Maytag M7DH45B2A Dehumidifier
Goldstar dehumidifer model GDH 30 wont turn on
first check outlet, some have a killer switch at base of unit, and if not setting level will not turn on.
Sep 30, 2011 | LG DH30 GoldStar Dehumidifier
My dehumidifer is not drawing any water, but the fan continues to run.
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture. humidity will be extracted from the air.
On most humidifiers the fan runs almost constantly while in operation. The idea is to continually move the air around and when the unit senses a rise in humidity, above what you have it set on, the compressor will turn ON to extract that humidity.
The 2nd thing that causes the problem is a dirty of clogged intake air filter. Which is easily solved by removing and cleaning the filter. Which should be done at least every 2 weeks, while the dehumidifier is in operation.
I said there were 2 reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Haier 45-Pint Dehumidifier
My lg dehumidifer is not collecting any h2o
I would first check the drain bucket the auto shut off may still be stuck or broken. I have run across this times before.
Aug 22, 2009 | LG LHD45EL Dehumidifier
I have a Goldstar GHD30 dehumidifer that I bought used last week. It's pulling 20-30 pints of water each day out of my basement so it appears to be working. The compressor only runs for 1-2 minutes at a...
yes cycles should be longer either that or the unit is keeping close to desired humidity. Also the unit is under sized 30 pint is for 400sqft. or 20 by 20 room. humidity should be 30/50 percent check your level desired room temp is 70 degrees but its a basemnt 60 works.
Jul 28, 2009 | Goldstar DH504EL Dehumidifier
Dehumidifier won't shut off
Well your dehumidifer runs constantly. My guess seeing how you bought a 30 pint per 24 hrs. Your house better be 400sqft. It is under sized and humidity need to be 30/50 percent to stop mold growth. It cant keep up its two small 50 pint are for 1000sqft 65 pint is 1300sqft. Upgrade now!!!!!
Dec 29, 2008 | LG DH30 GoldStar Dehumidifier
Unit runs but no water in storage tank
Make sure conditions are not too cold or too dry already.
Is the compressor running?
Set the unit to the continuous run setting or the dryest setting
compressor should start.
If compressor runs but the evaporator doesn't get cold the freon has
leaked out.
If compressor doesn't run no matter what you do the board may be bad.
Also the fan must blow air.
Sep 30, 2008 | LG DH30 GoldStar Dehumidifier
Loud Vibration
Check the front water bucket handle.
Sep 10, 2008 | Haier Dehumidifiers
Dayton 1DGX6 Dehumidifier Logo
222 people viewed this question
Top Dayton Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dayton Dehumidifier Expert? Answer questions, earn points and help others
