Question about Pioneer Televison & Video
I have a Pioneer DV-C505 and I have a small red light that looks similar to a record light displayed on the front and I have no idea what it is. Also I have no audio from it either. Its never been dropped or kicked or anything.
Nevermind...I'm an idiot
Posted on Aug 06, 2008
Lcd display light
what is price of display of nokia c505
Jan 31, 2014 | Nokia C505
L.S.My Pioneer DVR-550H does not record when programmed with the timer. After setting a timerprogram one can see the small red clock in the display but that disapears after some time and so the DVR does...
Make sure you have the right date and time set. You cannot set a timer program until you have the correct time and date set. Let me know if that helps.
Feb 20, 2011 | Pioneer DVR-550HS HDD Recorder
At the back of my Pioneer DV-414 DVD Player there are 3 sockets namely (component video out) which are Y (Green), Cb (Blue) and Cr (Red). Can I connect these to my TV which has sockets Red, White and...
You are describing what are called composite video outputs. Unless your TV has similar green, blue and red input sockets, you should ignore them altogether.Your Pioneer DV-414 has several different ways to link to other pieces of equipment. Depending on the sophistication of your audio/video gear you can have a higher quality video image using the S-video outlets which look something like the PS2 sockets on older computer keyboards and mice. If you don't see this socket on the back of your TV, and you don't see the composite RGB sockets either, then you will have to use the standard red & white outlet for left/right audio and the yellow outlet for video.
Hope this helps -)
Nov 30, 2009 | Pioneer DV-414 DVD Player
Will pioneer dv 410v have record timer?
It does not have any Record Timer.
Thanks.
Sep 20, 2009 | Pioneer DV-410V-K DVD Player
DVD player start to load and then stops
display driver malfunction.. no solution
May 26, 2009 | Pioneer DV-37
Red light above display flashes but no functions working
hi Dave
I'm not the most technical person in the world but I think I've fixed mine which had the same problem this afternoon, which is how I came to find your message!
Right.. here's what I did. It would appear that you have some kinda mechanism jam (even if there's no disc in it), so... please excuse my non-techie terminology throughout.
By the way, I probably don't need to tell you this but unplug the unit from the mains first or you might light up if you touch something!
Working with the unit facing you (control side), remove the two small screws at the back (on the metal flange) and two medium screws from the right hand and left hand sides of the main casing, then slide it off from front to back so that you can see inside the recorder. If you look in and down at the CD tray transport mechanism you should see a white plastic 'cog' wheel on the left hand side of the unit near the bottom 'floor' of the machine. Carefully rotate this wheel with a finger CLOCKWISE (pushing the wheel from front to back), slowly and gently - don't force it - and you should see the CD tray mechanism and gubbins start to move; keep rotating until the tray comes right out, or as far as you think it goes. Then, plug the unit back in, and switch on - the tray SHOULD then be taken back into the machine, the red light will flash, and the display should come on. As I say, mine has, so try it and I hope it works for you!
All the best (we'll beat these damn machines yet!)
Kev
Apr 16, 2009 | Pioneer PD-R509 CD Recorder
LED light dont come on!!! Pioneer audio receiver VSX-9700s
Do you mean that the display that show the audio source or mode doesn't turn on? Try shining a bright flashlight at the display and see if you can read it. If you can, then the backlight light bulbs have died.
Replacing it will be a pain but you may find a usable replacement at Radio Shack. Just measure the voltage that goes to the bulbs and find one with similar ratings. They are probably 12v lamps.You will need to remove the display from the front panel of the amp and desolder the old lamps. Getting at the bulbs is the hardest part.
Dec 25, 2008 | Audio Players & Recorders
Red power light flashing on and off
the same thing happens to me! idk how to fix it
May 05, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Sony DCR-HC42 Partial Screen Display
Sony has had some CCD problems with this and other model I think it is important to contact Sony at 1-866-703-7669
Nov 05, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
I can not get my CD recorder to record
You should use consumer cd's that are rather expensive. You probably tried to record a recordable cd-rom (a cheap computer disc). It's not possible to burn a pro-disc (computer disc) by using your Pioneer, and that's why you got that message on the screen. Refer to the user manual of your cd recorder and learn what sort of blank cd you should use.
Aug 05, 2007 | Pioneer PD-R555RW CD Recorder
Televison & Video Logo
71 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
