Question about Dishwashers
The touchpad buttons wont work. I have power going to machine. is it the touchpad or the control module thats bad?
    Master:
  • 354 Answers
The biggest thing to check is the door switch ,cause if the door switch isn't working ,nothing works-- 90% chance that is your problem.
Hard to tell from what you told me ,but I would make sure it's not unplugged in the back(the button board). Usually it's
the component that takes the most abuse. Ask yourself when did it stop and and what did you do to make it happen or why which will help in the diagnosis. Make sure you have voltage to the control board which could be a problem as well. If you have had a power outage it could have took out the rectifier which breaks the voltage down to dc or if you are lucky there is a fuse for the dc voltage look for it after on or before the control board. Most boards run on 12v or 15v just check and that will get you started.You can test the buttons by a continuity or resistance check just see if the two wires are making when you push the button all the way back to the control board,wiring goes bad as well. There are relays on the control board so push a button and tap a relay (looks like a cube) and see if it comes on or push the button and see if you hear a click of the relay on the control board.
Posted on Apr 05, 2011
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
Jan 24, 2013 | GE JE635 Microwave Oven
Fisher & Paykal MW512 turns on multiple beeps then turns off
This kind of problem is usually related to a faulty display module, or faulty motor control module (Computer isnide of control panel compartment)
Without spares to change and test with, you wont be able to diagnose 100%
Usually when there is a problem, a series of lights go solid on the control panel and the machine beeps to alert you to a problem and this is a fault code, but if nothing is showing at all, then I have to lean towards the display module underneath the touchpad. Especially considering it wont illuminate.
Nov 22, 2012 | Fisher and Paykel Fisher & Paykel Washer
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
ser Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | Kenmore 80809 Microwave Oven
Does not start
Hi, Does not start as in you plug the machine in at the wall and switch it on and it wont start? or as in the machine turns on but pressing the start button wont start the machine? If its not starting when you switch it on at the wall then in all probability its your main controller module that has blown. Replacing the module will incorporate a great deal of money as any power supply would for any appliance due to it being the heart of the machine.
In the case that the machine turns on but wont start when pressing the start button indicates to me that the machine may have a problem with its display module which in turn will cost a great deal of money being the brains of the machine either way its going to cost a great deal of cash
Also try inspecting the main switch board it may be that the fuse has been tripped due to overload from other appliances, hope this helps
Apr 30, 2011 | Kenmore Dishwashers
Emachines e725 Touchpad Not Working
The eMachines E725 has a built in switch to toggle the touchpad on or off by the touch of a button. Look at the button to the left of the main power switch. You'll notice the icon looks like a hand touching a rectangle - or touchpad. if this button is lit up, the touchpad is turned off. simply press the button to toggle the touchpad back on. The light on the button should now be off.
It's that simple.
May 02, 2010 | Acer Aspire 3000 Notebook
Keypad froze on lg microwave
Does it have a membrane type touchpad?
Just went through that. The touchpad was bad. Some numbers and functions would work - others wouldn't. Ended up replacing the touchpad. It cost about $31.00, including shipping.
Most touchpads attach with two side adhesive. The complication in the replacement usually involves the ribbon cable that connects the touchpad to the microwave control module. I had to disassemble the door to detach and reattach this cable.
Oct 16, 2009 | LG 30" Over the Range Microwave Hood with...
Continuous beep after power went off and on
I'm the one who posted on May 23. I tried turning off the breakers and it was still beeped when powered back on. I ordered a new touchpad and control module. When I replaced the touchpad, the beeping was gone, but not all the buttons worked, so I changed out the control module, too, and it works:) I'm going to put clear caulk along the top to prevent spills from leaking through the front panel.
May 15, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwashers Logo
67 people viewed this question
Top Dishwashers Experts
