Question about Toshiba REGZA 32AV615 32 in. LCD TV
Toshiba tv keeps on changing inputs at irreguar times on its own and the every button on the remote changes the input. have tried removing batteries from remote but problem continues
  • 1 more comment
  • t_bacon87 Apr 05, 2011
    yes all buttons on the side of the tv just change the input as well
  • mcrobbieg812
    mcrobbieg812 Mar 11, 2012
    Im having the same problems too, cant work out what the problem is. I have emailed Toshiba support, will see what they say.
  • samk
    samk May 27, 2014
    I'm having the same problem, anyone have any ideas?
    New Friend:
  • 36 Answers
There is a known problem with Toshiba Tvs that options change with out any input of buttons or remote. the tv switch panel needs replacement. This is situated behind where the buttons are on your tv usually bottom right. there is a work round if you dont want the expense of part replacement. you can disconnect these buttons and only use the remote. This requires taking off the back (ensure tv is disconnected from power as there is high voltage in the tv) once the back is removed and tv is laying on its front you will see bottom left where the buttons now are, a couple of cables one will have seveal wires and one will only have a couple of wires take the smaller one off this will disconnect the buttons and stop the problem. once this is done you can only use the remote control to control the tv settings but the power on off button still works.
I hope this was useful.
Posted on Oct 17, 2014
    Sergeant:
    Champion:
  • 277 Answers
Have you checked the buttins on the tv
Posted on Apr 05, 2011
I cant get any of my inputs to change my kids hooked up the Xbox and now none of the inputs work for cable or DVD its just a blue screen with a no signal can anyone help me tonight please
Kindly check first if the batteries of your TV remote ( medium to change input ) are fresh. After that please check again the button on your TV remote for INPUT, SOURCE, or TV/VIDEO and it should give you input lists.
May 12, 2014 | Televison & Video
No remote and need to change input on a toshiba 27a45
If you do not have an input button on the TV then you need to get a remote. I have owned a lot of toshibas. Use the channel down button on the tv and keep hitting it untill you get down to the last channel. after that it should start cycling thru you inputs. Good luck to you.
Mar 21, 2013 | Toshiba 27A45 27" TV
TOSHIBA 32AV502 Wont Turn On
Ensure that the input device and the connections are ok. Try changing the input device to something that you know, works. Try controls on the panel of TV. Remove battery from remote, before you do that. Try connecting the TV to a different power outlet. If nothing works, this might require the attention of a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
Lost remote. Trying to change tv input to tv video 3.
Unfortunately, you do need a remote with a TV/Video Input/Source button. http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12931505715290&smodel=32AF45&brand_pn=TOSHIBA_32AF45 has a substitute with all of the features including the TV/Video button. Any remote programmed 6 months after the TV was released will probably have a code that works with the TV. However, the lowest end ones often do not have an Input or Source button. With a remote with that button, it may take a while to find a code that matches all of the features (keep trying).
Any of the universal remotes that can be programmed via a USB connection to a computer will work with much less effort.
I hope this helps.
Dec 24, 2010 | Toshiba 32AF45 32" TV
Toshiba 27A41 27" TV Remote is lost. Need to change the input. Can I do this using the buttons on the TV? Can I program my DirectTV remote to change the input?
You can't chage it with your Direct TV remote control. If there is menu button in front of the tv, just go through the menu, and see the vedio options. From there you can change the input selection. If there is no menu button, you can't do anything without the help of remote control handset.
Oct 15, 2010 | Toshiba 27A41 27" TV
Channel buttons change input
Auto channel search is your friend. Once the tv has been through it and finds active channels, your channel button should work the way you envision.
Jul 06, 2017 | Toshiba 15LV505 LCD TV
I have a Toshiba 24af42 with no remote. I am trying to change the input, but without a remote I cannot figure out how to change it. I have tried a universal remote which works for other functions, but not...
Try this website 1-800-remotes Factory original u can buy an original remote,tries Channels up or down couple times u should get in the input 1 or 2.
Oct 22, 2009 | Toshiba 24AF42 24" TV
How can I use the input on my toshiba TV without a remote?
You can change your inputs by pressing the menu button on the panel of your television.
Aug 07, 2009 | Toshiba 14AF44 14" TV
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Mar 16, 2008 | Toshiba 24AF45 24" TV
Toshiba that uses CT-90040 remote
Is the cable remote a programmable universal? If so, just a matter of finding the codes to reprogram functions.
Concerning the "tuning video", are you saying that you can't get to different input sources?
Oct 15, 2007 | Toshiba 36AF42 36" TV
Toshiba REGZA 32AV615 32 in. LCD TV Logo
1,127 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
