Question about Dynamic American Dynamics ADTTE Keyboard, RS232, Touch Tracker, trackball control, desktop
Hello i have a touch tracker ADTTE and it have UC- on is monitor but he doesn't work and i don't know how to came back to normal fonction. So please, help me..... Sorry for my bad english speaking :D
Power Supply bad working. Blue led doesn't light.
Hi, I'm having the same problem with one of mine M1 Active 620. Please have you found out characteristics of D5 Zener diode, voltage?
Nov 13, 2012 | Alesis M1-Active-MK2 Powered Studio...
Hi, Do you know the "sneaks" for preventing my 1998 Saturn SC2 from getting stolen? I heard there is a master key you can buy on the internet. Anything else I should know?
i don't know about any master key, i would say that is just a rumor. Also, don't think there is way to keep any car from being stolen if they want to steal it. However, i do have a good suggestion for you, for $30 and free shipping, i bot a gps tracker to hide in my car. if my car is stolen, i can see where it is at all times and notify the police of its location. here is the gps tracker i bot: it says it is a child tracker, but i don't care, works the same way.
http://www.cowboom.com/product/667860
if this is at all helpful please give it 4 thumbs up to help others. Thnx for your question!
Jun 14, 2011 | 1998 Saturn SL
My stand will not go back so I can attach the base...please assist
Hello and welcome to fixya.
I believe you are trying to assemble the monitor and you don't have the manual in hand so here are two links that might help you out:
1. The hp w1907 user manual - see page 13 for assemble instructions or page 22 (if you are looking to only adjust the monitor height).
2. An eHow.com brief explanation.
If you are looking for disassembling the monitor itself to repair it, please let me know so I can re-post another solution although there are a couple of youtube videos already online to show complete repair instructions for the specific monitor.
Let me know if this helped you at all for this.
**Don't forget to rate this solution**
Thanks.
Regards from FixYa.com
Apr 16, 2011 | HP w1907 LCD Monitor
Hello the bottom of my stove doesn t light i
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 29, 2010 | Hotpoint RGB745 Gas Kitchen Range
Monitor problem
Hello Iceage, hi, problem is within your power supply section on the LCD. cannot be specific, but normal repairs usually replacement of large value, and large voltage rating capacitors, especially ones were the cathode is connected to ground. check also for the switching power transistors, usually they are MOSFET. you can either do it yourself, but you need the expertise of electronics, or get professional help.
Apr 15, 2010 | Televison & Video
Have a problem with my computer. I clicked on sleep mode and it turned off, but when I tried to wake it up after about 5 -7 minutes, it gave me a sign that said ?No signal ?..?something.? I don?t know how...
Hello
1st try clicking mouse and moving it around.
2nd turn monitor off then back on.
Last unplug pc and monitor from all power for a minute or two to reset motherboard.Plug back in and start up pc.
Should wake it up.
You may get a notice the windows did not shut down correctly,just choose to start windows normally.
Hope this helps.
Jan 23, 2010 | Acer Aspire L100 PC Desktop
Sony SDM-HS74P/S 17 - Monitor won't stay on the right picture
When the screen turns black again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Mar 16, 2007 | Sony SDM-HS74P/S 17" LCD Monitor
CRT Monitor-Compaq presario VM700
Hi Snandy, I absolutely despise monitor and computer sleep or hibernation modes. Before I started routinely disabling this on all the computers I supported my users were always having problems no matter how computer literate they were. I know this sounds simplistic and you may have already done it but have you just unplugged the monitor? If that doesn?t work maybe the PC itself has gone to sleep as well. Try moving the mouse, hitting a keyboard key. If that doesn?t work try pushing the power button on the computer to turn it on. If all else fails pull the power plug on the computer itself, plug back in and it should start up. I would suggest disabling all of this via Windows Power settings in the control panel. Let us know if you have any other questions and again please don?t forget to rate the post.
Feb 02, 2007 | Compaq V700 17" CRT Monitor
Dynamic American Dynamics ADTTE Keyboard, RS232, Touch Tracker, trackball control, desktop Logo
300 people viewed this question
Top Dynamic Home Security Experts
Lawrence Oravetz
Are you a Dynamic Home Security Expert? Answer questions, earn points and help others
