Question about LG French Door Cabinet Depth Refrigerator 21 Cu. Ft. - LRFC21755
We have an LG LRFC21760ST french door fridge. One of the plastice door catches at the top of the fridge door is loose (causing the door not to seal properly when closed) and something seems to be broken in behind the magnetic seal. How do you take apart the door and seal to get a look at that mechanism? I'd like to try and fix it myself. Thanks for your help.
aborcass
  • 2651 Answers
SOURCE: Ice Flap on my LG LSC26905TT will not close after ice dispences
ran into an LG tech today with identical problem and was told to replace a solenoid that closes the door flap.
Posted on Mar 06, 2008
  • 2427 Answers
SOURCE: french door frig model # pf22sbsbss
A local hardware shop or dealer should have the seals, its a common thing..
Posted on Jul 22, 2008
cresguy
  • 75 Answers
SOURCE: outside of fridge condensation; hissing boiling noise
under the compressor there will be rubber bushes which would have got damaged so change the rubber bush and ur problem may get solved
Posted on Jul 25, 2008
SOURCE: Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Posted on Apr 21, 2009
cj2176
  • 520 Answers
SOURCE: Ice tastes like plastic. New LG French Door.
Change the filter each week until problem is gone. LG is not usually hit with this problem. good luck.
Posted on Jun 09, 2009
The door flap on my KitchenAid French Door fridge isn't springing completely back into place, and it's catching on the other door.
Locate and adjust the spring responsible for getting that flap into proper place and all will be resolved.
Aug 30, 2015 | KitchenAid Refrigerators
I have an LG refrig french door model LFX 31925ST/00. Purchased less than 2 months ago. The top plastic freezer door continues to get an ice build up on the front of the drawer only. Is this normal? ...
It sounds like a loose or bad seal on the top area of the freezer door. Use the old dollar bill test to see how good the seal is. Hold a dollar bill up to the seal and close the door. there should be some resistance. compare the resistance between the top and bottom of the door.
Nov 06, 2017 | LG Refrigerators
My Kenmore Elite french doors bottom freezer drawer fridge has condinsation in the top of my fridge what is causing this?
bad/dirty door seals allowing fresh moist air in.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 24, 2009 | Kenmore 24.8 cu. ft. Trio French Door...
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
My freezer is frosting...there is snow all over
In my case with constant snow and frost build-up in my bottom drawer GE freezer, it was because the drawer never properly closed. As one user noted, "there is no adjustment." However, there are "catches" at the rear of the drawer glides and in my case one needed adjustment because it was preventing the drawer from remaining closed tightly. SEE PHOTOS. The photos show many items removed, but to make this repair, you only need a butter knife to pop out the black plastic catch mechanisms at the back end of the drawer glides, and only if you can see that the spring is not properly positioned. SEE PHOTOS
May 09, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Regrigerator shows error code 1F
Hello tr-6
Welcome
You Wrote,
LFX25960ST LG FRENCH DOOR REFRIGERATOR DATE OF PURCHASE 7-7-07 DELIVERED 7-13-07 ICE MAKER REPLACED ABOUT THIS TIME LAST YEAR AFTER TWO MONTH WAIT. NOT PLEASED WITH PERFORMANCE OR SERVICE TO DATE. REQUEST THIS PROBLEM BE COVERED BY WARRANTY.
Below is the service manual And the explanation for your error.
Thank You for using our site.
Huuum
Please remember to leave a solved rating.
Error Detection Category
ERROR CODE : IF
Abnormality of
BLDC FAN Motor
for Ice Making
Error Generation Factors
It is caused when F/B
signal isn’t over 115
seconds during BLDC
FAN motor operating
Remark
Poor BLDC Motor
connection, DRIVE IC, and
TR
Resource reference located here:
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Huuum
Oct 12, 2008 | LG LFX25960ST Stainless Steel French Door...
LG Fridge...door strickers
here is a link to an exploded view of your fridge model.. which parts are you looking for? Perhaps your description of the part differs from mine.. what is the part you need? Please be specific so I can assist you in finding a supplier...
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Exploded.pdf
Aug 10, 2008 | LG LFX25960ST Stainless Steel French Door...
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
LG French Door Cabinet Depth Refrigerator 21 Cu. Ft. - LRFC21755 Logo
237 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
