Question about Whirlpool Dryers
I have a Whirlpool Creations AWZ121 Dryer which no longer heats. I was told by an engineer that the humid conditions over the extreme Winter may have caused one of 3 thermostats to switch off - but that they can be re-set by pressing a small red button next to the heating element. Fine - except I can't find this button. Are you able to assist please in telling me if it exists, if so, where it is located or help in any other way? Many thanks - Diane
watugot
  • 290 Answers
SOURCE: Kenmore Electric Dryer Model # 110.62622101
I think on your machine the lower thermostat connected to one terminal of the element, you have a wire coming from the thermal cut off down to the top terminal of the lower thermostat, a wire from the lower thermostat to the timer, and a wire going to the other terminal of the element.
You probably have the wire from the cut-off correct as it won't reach the other terminals. You have crossed the other 2 wires. This caused 240V to short across the lower thermostat and burned it out.
You will need a new Hi-limit thermostat, which will include the upper cut-off as well. They come as a set part# 279816. This will be a little different because the new hi-limit will not connect directly to the element. There will be all the wire ends and instructions with it that you need to get it hooked up correctly.
There should be a wiring diagram inside the console of the dryer that shows which wires go where, but I am sure you have crossed the 2 wires below the hi-limit switch.
Post back if you need any help.
Thanks/Mike
Posted on Dec 02, 2007
  • 351 Answers
SOURCE: no heat in my whirlpool
there may be a loose wire somewhere are you getting an active supply to the element,or may be a break in the nuetral.its difficult to explain how to find out.from my experience it always been an element fault.hope this helps let me know,ans i will try and think of something else.
Posted on Mar 08, 2008
jsrock516
  • 5911 Answers
SOURCE: Dryer Top Hot / New Heating Element Smell
Any time you perform work inside a dryer, lint can get kicked around and settle on components. It is common to have a slight burning smell for a day or so. However, your dryer getting too hot to the touch concerns me. Improper air flow is the number one cause of dryer overheating problems. You may have cleaned the lint out of the interior of your dryer, but did you check the air blower and vent duct lines? In addition, was the heating elements actually bad? Or, did you assume it was bad, because your dryer wasn't drying properly? The following link can explain:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. I would recommend you remove the vent hose from the back of the dryer and attempt to dry another load. If the dryer dries more efficiently and the top panel does not get scorching hot to the touch, then you have a vent clog somewhere EXTERNAL to the dryer. If the dryer air flow exiting the dryer is weak and the dryer still gets too hot to the touch, you have a clog INSIDE the dryer.
Follow these steps, first and see what you find. If you verify your ventilation is clear and not kinked or clogged anywhere, then you might assume you have a component malfunction. I would hope to try to save you from purchasing parts you may not need. I hope you find this information helpful. Let me know if you require additional assistance.
PS Make sure you are using semi-rigid (metal type) vent ducting. It is crush resistant, heat resistant, does not kink easily, and resists rodents. It is what most manufacturers recommend. If you haven't replaced the dryer vent in a while, this may be a good time.
Posted on Nov 18, 2008
  • 208 Answers
SOURCE: my front loader dryer stopped heating,
have a electrician inspect the circuit going to the dryer as it might not be providing proper current to operate the dryer
Posted on Jun 22, 2009
SOURCE: Dryer works but no hot air
did u get an answer i have the same problem
Posted on Oct 12, 2009
What are the recommended settings as far as % of humidity and room temperature? Does this set automatically?
Humidity is said to be good at 50% RH and temerature at 77*F. Air looses humidity when it is heated or cooled. Extremely humid conditionals it difficult for air conditioners to cool the air.
The temperature to be comfortable in varies from person to person.
Aug 11, 2017 | Dehumidifiers
What is the most efficient setting for heating
You can find information on the web by doing a search; "efficiency setting for air conditioning (or heating)"
Jun 13, 2014 | Panasonic CZ-RTC2 Wired Timer/Remote...
Whirlpool tumble dryer awz121 not tumbling clockwise ...
if it tumbles in reverse but not forward then it may be your reversing relay is only working on one side.
Oct 31, 2012 | Dryers
Do not gt hot it works but an not dry its a whirlpool creations
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 13, 2011 | Whirlpool Dryers
My gas dryer heating but it is taking 3 times longer than it should
The very first thing to do is clean out all the venting system. Inside and out.
Then check that the flames are igniting and providing good heat to the dryer.
Nov 10, 2010 | Whirlpool LGQ8000JQ Gas Dryer
Whirlpool Craetions Dryer AWZ129: No Heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 15, 2010 | Whirlpool LER5636P Electric Dryer
There are a number of things that can cause these problems...
Check out this tip it will help you...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Mar 29, 2010 | Whirlpool LER5636P Electric Dryer
My whirlpool awz121 dryer does not heat up anymore what can i do
You either most likely have a bad thermal fuse or broken ignitor. When you turn the dryer on, do you hear a click after a few seconds. Thats the sound of the burner powering up. If you dont, you most likely need a new therma fuse. thanks Dave www.washermd.com
Dec 08, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
101 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
