I have an Ideal Isar m30100 combi gas Boiler. It stopped working An egineer called and replaced the Pcb got it working but stops after a few hours a green small line comes up on the display control but No error message ! this has been replaced along with the connecting wires and clips . Still have the same problem!!!
  • Roger Jelinek Apr 07, 2011
    How long does it stay off? what do you do to get it to restart?
  • Anonymous Apr 09, 2011
    Hi , It will start as soon as you switch the power off and then on like a reboot !!
    It will run then for a few hours and then at some point it crashes ...
    no hot water or central heating !! Ideal tech line seem to be pulling at straws the engineer has done everything they have told him but no joy!!!
    thanks Richard...
  • 13 Answers
SOURCE: f20 error on vaillant eco28
F20 is a flow sensor error. Can be due to a defective sensor/ not correctly fitted, or you may have poor circulation, a big difference in flow and return temperatures, can sometimes make the boiler think it has a defective sensor, check good circulation through system, or if you have thermostatic radaiators valves on every single radiator, take 1 head off, as if you dont have a bypass fitted, it needs a radiator as a bypass circuit
Posted on Mar 03, 2009
  • 234 Answers
SOURCE: I need an Instuction manual free to download for
http://www.screwfix.com/talk/thread.jspa?forumID=25&threadID=27577&messageID=268842
I hope this help you.
Posted on Mar 19, 2009
  • 30 Answers
SOURCE: Vaillant combi boiler problem
when the tap is turned on and the water light on the boiler doesn't this means the diverter valve is not operating it could be down to low water pressure in the house this can be checked at the cold tap in the kitchen. if there is plenty of pressure then it could be the diagphram in the diverter valve is worn or split. the diagphram is only a few pounds but it depends on the engineer you get as to how much money he wants to fit it.
the egg timer symbol (or two pyramids together) is an ignition indicator turn off and on again to see if it will fire with the tap running. reset the boiler with the lower right hand control knob.
Posted on Mar 26, 2009
SOURCE: We have a Worcester Bosch Highflow 400 (10 year
The by pass pipe may be limed up. This apparently causes a reduced flow which will stop the heating side of the thing working. Call out Worcester Bosch engineer. It costs £210 including VAT and most parts and they almost guarantee to get it working.
Posted on Dec 02, 2009
  • 2840 Answers
SOURCE: Hi I have a ideal isar 30100 combi boiler which
jumper links not inserted in to pcb is h5 code
Posted on Mar 21, 2010
Testimonial: "Hi mylandlord eventually sussed it out and blanked of port1 and 3 on the pcb thanks for your help T"
My isar he30 ideal boiler has no life no power nothing
if voltage to unit check transformer voltage
Oct 08, 2017 | Heating & Cooling
Boiler keeps blowing fuses in pcb ideal isar he 30
The model # you listed is for a vent-free, natural gas, space heater and requires no electricity to operate. Unless, you have the optional blower. If the blower accessory is what's blowing the fuses, there is a short in wiring to the blower motor. Other than that, there is nothing else about this heater, that would be blowing fuses.
Is the above, the problem you're having? If so, unplug the blower from the wall outlet, until it can be repaired or replaced. The heater will continue to operate and heat with out the blower.
For more information about your heater, go to the link below.
http://www.desatech.com/manuals/Vent-Free%20Heaters/107882-01.pdf
Mar 04, 2011 | Desa International CBN30T Central Heating...
Ideal isar 30 he making noise when going too low falme checked condensate trap replaced pcb n fan still noisy when on low flame
. is the flame detection probe or its wiring harness, this sits right on the heat ex and over time melts and sticks to the heat ex so looses continuty.
To check if the detection probes faulty, get a multimeter pull the wiring off the probe stick one end of multimeter on probe connection, other end to the wiring plug, set your multimeter to mirco volts. fire boiler up. you want more than 1.5MV's or probes is knakered! Check continuity of wiring, also check wiring is full pushed in to the white molex connector too.
May 14, 2010 | Heating & Cooling
Blank display on ideal isar 2 he 30
may just be a defective display PCB, byt more often than not, its the more expensive main primary PCB. Ideal actualy modified this PCB, and has a pre-fix of VF on it, and is orange in colour
Feb 18, 2009 | Honeywell Programmable Thermostat Heater
Ariston A01 fault combi boiler
its not definately the pcb. change the detection sensor first( £3.20p). if this doesnt fix a01 fault then change the main pcb(£145).
Oct 29, 2008 | Water Heaters
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
