Question about Gateway Computers & Internet
I turned on my laptop and i get a "system fan error" message that says "turn off system and check your system fan!!"
  • 144 Answers
If you are not a technician, please do not attempt to service yourselves. Take your laptop to the service center.
Posted on Aug 06, 2008
New case fan running but still getting error message system fan failed.
Did you try;
Power off, power unplugged to computer.
Press the Power On button, and hold it in. Hold for a count of 10 seconds.
Let go.
Do this procedure two more times.
Plug the computer back into power. WAIT 1 minute, turn the computer on.
This method clears CMOS Error Codes, and sets BIOS Setup back to the factory default settings.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864946&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3340228#N436
CPU fan spinning at required minimum RPM's?
Not talking about the SYS_FAN (Case fan)
Regards,
joecoolvette
Jan 18, 2013 | HP Pavilion a1720n PC Desktop
Tip
How to verify that the CMOS battery needs to replace
<p>The CMOS battery is named after the Complementary Metal Oxide Semiconductor power. The CMOS has the current date and time functions for desktop and laptop computers. It allows the computer to automatically adjust the time, even on computers that are disconnected for long time. When a computer no longer has the date and time and forget it on every boot, the CMOS battery probably needs replacing. Some computers have messages when the battery is weak, while others just lose the current date and time after each shutdown.<br /> <p>Time & Date Errors<span> </span><br /> <p><span> </span><br /> <p>1. Turn on the computer. Look in the task bar at the bottom right. Make sure the date and time is set correctly. Double-click the time and click the up or down arrow to switch to the correct time. Click on the arrow next to month to change the month. Click "OK" when finished.<br /> <p><br /> <p>2. Turn off the computer. Wait 3 to 5 minutes and start the machine.<br /> <p><br /> <p>3. Look on the taskbar to see if time was lost and said a strange date January 1, 2000. Replace the CMOS battery, if this is the case.<br /> <p><br /> <p>CMOS Error Message<br /> <p>1. Look for error messages like "CMOS checksum error", "CMOS Read Error" or "CMOS battery failure" when you start your computer. These errors are caused in the machines shut down for several months or when the CMOS must be replaced.<br /> <p><br /> <p>2. Let the computer on for 24 hours. Restart the computer and find the error.<br /> <p><br /> <p>3. Change the CMOS as the return error.<br />
on Jun 21, 2011 | Computers & Internet
My HP e9120f gave me the following error message the other day. "reboot and select proper boot device..." My first thought was my hard drive was bad. I could turn off the computer and after a...
You might have another part that has gone bad. Check the RAM and see if it gives you any problems.
There is a program call mem test that you can burn to a CD and test your memory. But if your no longer able to get to the bios:
you def had a hardware problem.
May 04, 2011 | HP DT PAVILION ELITE E9120f DESKTOP PC
When i turn on my hp compaq dx2200 desktop pc it give a fan error saying "no system fan found"
Try opening the case and ensure all the power cables from the fans to the motherboard are securely connected.
Mar 30, 2011 | HP Compaq Business Desktop dx2200 - P4 524...
WHEN I TURN MY COMPUTER ON A ERROR MESSAGE COMES ON "CPU FAN TO LOW"
This message is a warning that the CPU cooling fan is no longer turning fast enough to adequately cool the CPU. You should not use your computer until the fan is replaced.or the CPU could be permanently damaged as a result of over-heating.
Unless you have replaced these fans before, I would advise you to have the fan replaced by a PC technician as it's pretty easy to damage the processor when removing/installing the fan.
If this information is helpful to you, please rate me on the FixYa website.
Rich
Nov 28, 2010 | Computers & Internet
A message says "previous fan
my dell gx 280 fan failure how i solve it'
Nov 23, 2010 | Dell OptiPlex GX280 PC Desktop
Fan quit working on laptop. I've heard conflicting information from stores today about whether or not new computer is needed or this being repairable. When I turn on computer, it says "system fan...
Hi There,
The message that you are getting from your computer system is because the motherboard has got very hot and therefore requires new motherboard and the new fan will come with it. I would buy a new computer instead of repairing this one due to the cost involved.
The answer to your data is yes... your hard drive can taken out and the data copied to another system, or even burned to cd. I would buy an external drive kit from pc shop and instert your drive into it and use it as an external deive on your new laptop.
Please let me know if you need more help.
Regards,
Philip
Dec 01, 2008 | Gateway Computers & Internet
Here's more info to my problem: Gateway laptop is 4 years old. Now getting message that says "System Fan Error!! !!Please turn off system and checkyour system fan!!" Computer was purchased...
Your CPU fan has failed! your heatsink overheats quickly and then shuts down to protect itself from burning up. Your motherboard is Not the problem, the fan is. This fan can be replaced by any compotent laptop technician. Make sure the tech has access to Gateway or has a source that supplys Gateway parts, as the part must be made for Gateway laptops and your model exactly! 90% of this type of problem can be repaired! Don't let non-techs at Best Buy or any other dept. store tell you your PC is "No Good". Take the time like your doing and do some research the problem before giving your hard earned cash to a 16 year old "Technician/salesman/commision/bonus" person.
If the Harddrive is undamaged and it can be mounted yes, your stuff can be saved to DVD or such. Be prepared though, this type of service can be costly so ask around and get quotes.
Nov 30, 2008 | Gateway Computers & Internet
On shutting down my laptop it gave the message, "installing 1 of 1" do not turn off your computer. It did not turn off all night. I turned it off by using the on/off button then shut it down...
When you start your laptop, press F8. You will get a menu (Normal boot, Reboot...). Choose Last good known configuration (something like that).
Aug 20, 2008 | Acer Computers & Internet
When turning on my hp compaq 6720 laptop for the first time the battery went down while windows was starting and now i receive the following error message when booting up "the computer restarted...
This issue could be dude to a number of things, Probably the best thing to do would be to either start in safe mode, and see if there is an application that is causing the error, Or reinstalling the operating system from the windows CD.
Jun 03, 2008 | HP Computers & Internet
Computers & Internet Logo
90 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
