Question about Hotpoint Aquarius WF000 Front Load Washer
How do i change bushes on my wf440 - Hotpoint Aquarius WF000 Front Load Washer
  • Hotpoint Master
  • 1,525 Answers
Hello go to this site www.espares.co.uk it will show you how to replace them or youtube hope it helps
regards
shaun
Posted on Apr 05, 2011
Wont pump out -so stops and the on/off button flashes. it empties if i place the hose on the floor. so seems as though the pump has brocken ? any help would be appreciated. thanks
I agree, or the "belt" that drives the pump is broken or slipping. Or it has a separate motor and it is not functioning properly.
Jul 06, 2015 | Washing Machines
Front strutt bush very loose , steering very woolly replaced wishbone and track rod ends only thing i can think of is new bushes to solve the problem.
If the bushings are worn, then it is best to replace them. If changing the other parts did not solve the problem, then have the bushings changed.
Jun 21, 2010 | 1988 Audi 80
Aquarius wf440 is tripping rcd tried the element but reading 34ohms
remove plug from socket . and then remove motor plug if your able from motor .and test motor .
Feb 11, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine not rinsing and spinning wf440
I would suggest that you check and clean the pump filter.
This is to be found by removing the lower panel of washer, then remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Hotpoint WF430 Front Load Washer
The machine when it is on a cycle sticks on the rinse spin
hi..most likely the timer switch which might have got
into trouble,this controls all the different cycles.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Problem with wf440 hotpoint
check to see if door is locked may be interlock
Dec 19, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF440 BEARING REMOVAL/REPLACEMENT
Are you talking about the main tub bearing?If so I dont recommend replaceing this bearing,because the problem will only keep repeating itself.
May 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
WF440 drum locked solid
easy check is to remove the little panel at the back and look for dirt marks on the bottom and running down the back of the drum...
from experience if your machine was noisy before when it was running then yes your bearing has gone..
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
103 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
