Question about JVC AV-36P902 36" TV
My JVC AV-36P902 is turning on and off by itself
When I turn on my TV it starts turning on and off very quickly (like flashing) for 10-15 times and then turns off. It turns so quickly that you can't even see the picture on the screen.
Any suggestion?
  • 125 Answers
Power supply problems maybe the regulator
Posted on Aug 06, 2008
How to remove deaf writing display on screen
Ur tv remote control have a CC button,push that button turn off everything like CC1,2,3 to all off.If no CC button on the remote.Go in ur tv menu.Pick out in the menu,the captioning in the menu turn everything off like CC1,2,3 and also TEXT1,2,3 off too.U will have no writing on the screen.
May 26, 2010 | JVC AV-36P902 36" TV
Picture and sound going out- flashing lights
the problem its the main board it controls everything if no warranty go to www.shopjimmy.com better prices better than manufacturer and tv repair man
Apr 13, 2010 | Samsung LN46B650 46/49.5 in. LCD HDTV
My tv will not turn on and the on timer light is
Try the following blog. It has detailed instructions on how to fix a common problem on this JVC TV series. I did and I fixed my TV for 2 bucks at home.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 14, 2010 | JVC AV-36950 TV
My JVC 27" can not be turned on or off with the remote or the on an off button. Any ideas?
try all in one remote/it can be the infrared on tv not picking up signal/point remote does light flash on tv ?
Dec 23, 2009 | JVC AV-27530 27" TV
JVC AV-K21T: TV goes off by itself
U know how to solder right?Take the backcover off take back of the handle screw driver taps where the part said it flickker or video back on, resolder that.
Sep 27, 2009 | JVC AV-20D303 20" TV
Projection tv won't turn on
Ur DM power board is dead,have burn capacitors,check all the puff up capacitors,and replace it.
Sep 22, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
2005 Hummer H2 battery went down and when I replaced it the alarm keeps going off and it will not start.
if it is the factory alarm you will have to do a relearn. G.M. uses a couple different ways to do the relearn and I would think it would be the same for hummer. turn off all acc and then turn the key to the on position wait 10 minutes you will see the light on the dash flash and go out . asap turn the key to off to on 3 times quickly and the third time leave it on on again do this 3 times for 30 minutes then after the final turning of the key 3 times on the 4th time start the car. so turn off all acc like radio , a/c ect then turn key to on in 10 minutes the light on dash will flash and go out quickly turn key from off to on 3 times and once again leave on on do that 3x for 30 minutes then start the car. that is the gm relearn for security they have one on some models that start after 10 minutes but that is usualy on the cheaper cars so just do the 30 minute.
Jun 04, 2009 | 2006 Hummer H3
JVC tV D series will not turn on when I hit power
Hi There,
Did you try turning it on from the actual TV power button?
Mar 22, 2009 | JVC AV-32D305 32" TV
JVC AV-36P902 36" TV Logo
222 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
