Question about Lancaster Kamata Dial OLA0344RG/MR Watch for Men
I have problem how to adjustment the Day and Date Lancaster watch model OLA0344RG i have this watch from bidz.com they sure this watch %100 authentic
  • robjagosky Apr 22, 2012
    I have the same problem. Did anyone figure out how to fix this???
  • 29 Answers
SOURCE: to adjust time on a watch
If your watch has a crown that pulls out to set it pull crown out half a click. Then turn crown to set watch to proper dte.
Posted on Mar 01, 2008
escapement
  • 2334 Answers
SOURCE: how to adjust day date on older rolex perpetual day date watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Posted on Mar 07, 2009
SOURCE: Calendar "Day" is stuck beteen days
pull the dial out half way, and turn it forward to adjust the day, and dial it backward to adjust the date.
Posted on Jun 21, 2009
  • 3 Answers
SOURCE: adjusting Date and day on a Festina 3 dial watch
Alhamdulillah, the problem solved (at last) tks to IRONMAN (http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2. and then push it one click (dont push it to hard so it back to normal position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solved
Posted on Jul 05, 2009
vetteman3002
  • 2299 Answers
SOURCE: I need to find a
Here is one. You are right. They are very hard to find a band. I found lots of watches. But the band by itself is very difficult to find. But here is a link to one that I found. It shows in the picture with a watch too. But it is for the band, tools to change it and instructions. Here is the link.
http://www.squiggly.com/us/en/swatch/white-ceramic-strap-ayls141g.htm
Posted on Dec 14, 2010
My watch is changing date at 2 am instead of at midnight, i have tried rechanging it manually, but still each day at 2 am it changes the day again. Why it not change at 12am O'clock what I can do pls
Thread: Tag Heuer Carrera changes its date at 3:00 am instead of ...
forums.watchuseek.com > Forum > Watch Brands > TAG Heuer
Jan 1, 2012 - 6 posts - ‎3 authors
The watch used change the date, as it should, at midnight but I just noticed last night that it now waits until 3:00 am... Does anyone have any ideas. ... Join Date: Jan 2012; Posts: 2 ... Changing the date on an automatic watch - Watchuseek ...
Mar 2, 2015
Damage of changing date at midnight on automatics ...
Oct 18, 2013
Setting the date destroys the watch? - Watchuseek, The ...
Sep 8, 2010
Thread: Does setting date between 9pm and 3am damage ...
Jun 6, 2010
More results from forums.watchuseek.com
How do analog watches know to change the date at ... - Quora
https://www.quora.com/How-do-analog-watches-know-to-change-the... QuoraThere is a gear within an analog watch that is used to change the date at the appropriate time. The gear ... Watches: What is a fair price for a authentic 1970's vintage "McQueen" Rolex Explorer II? Why does the day start at midnight?
Jan 21, 2016 | Watches
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
How to adjust day?
If the day is in a window next to the date, pull the crown out one position to the same position used for the date correction. Often turning one way changes the date, turning the other direction changes the day. If your day is on a small dial on the watch dial then pull the crown out two clicks and go around 24 hours at a time and you will see the day advance.
Dec 18, 2011 | Cerruti 1881 Watch
I'm looking for the manual instructions for my LANCASTER Watch 0346 I dont know how to adjust the date or knows about it
Pull out to the "winder" to the first click. this is to change the date. The second click is to change the time.
Changing the date - rotating the winder (if you were looking at it) in a clockwise directions changes the major decimal - the number on the left e.g. 0, 1, 2, 3. Rotating anticlockwise changes the lesser decimal - the number on the right e.g. 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
Hope that helps.
Jun 01, 2011 | Lancaster Lanza Gold and Dial OLA0346YG/NR...
Invicta model 4562 7750 valjoux automatic movement. Day and Date are difficult to set. Move crown to second (B) position, sometimes the day of the week adjusts, then the date will not adjust moving the...
Hi Friend,
Please check with the below link,which gives the detailed information about the Invicta Watches.How to set the Date and time in your watch.
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
If you have any Clarification please write back to us
Regards,
Aysaam
Jun 13, 2010 | Watches
Model 2302 how to back up date?
You should not be able to unscrew the crown from the stem by turning in either direction. So don't worry about that.
If your watch only has a date then you can "quick" change it by pulling the crown out to the first click and turning the crown. One direction will change the date. If your watch has both day and date then one direction will change the day and the other will change the date.
You will have to go forward counting the date upwards. You won't be able to make it go backward.
Once you have the date set push the crown back in and if it screws down be sure to screw it down so it is sealed.
Hope this helps,
Ken
www.yellowstonewatch.com
May 13, 2010 | Invicta 2302 Wrist Watch
SETTING (DIGITAL) DAY/DATE ON THE FOSSIL JR9387
Follow this link and download proper instructions:
http://www.fossil.com/webapp/wcs/stores/servlet/StaticView?langId=-1&storeId=12052&catalogId=10052&page=Instructions&nav=custCareNav
Rate me, please.
Mar 24, 2009 | Fossil JR9388 Watch
Adjusting Date and day on a Festina 3 dial watch
Sep 05, 2008 | Festina 161625 Wrist Watch
Lancaster Kamata Dial OLA0344RG/MR Watch for Men Logo
85 people viewed this question
Top Lancaster Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Lancaster Watch Expert? Answer questions, earn points and help others
