Question about Roper RT21AKXKQ Top Freezer Refrigerator
Replacing the electrical cord on a Roper Refrigerator
I want to know how to replaced the cord on a Roper refrigerator. The cord was pull out of the refrigerator now I am trying to reconnect the cord so I can use the refrigerator. Thanks
  • 1 more comment
  • Henry Sanchez Aug 06, 2008
    The cord was pulled out of the Roper refrigerator but now that I have a replacement cord I have no idea where to connect the black wire and the white wire a the ground wire. I see an inlet with six spaces where where five wires could be connected to.
  • Anonymous Sep 24, 2008
    roper mod rt21lmxjw01.cord got riped out with the 5 pin black connecter. the wireing dia gives you the color of the wire but not where it goes in the connector. need to now the location of wires in connector
  • Anonymous Mar 16, 2014
    I moved the compact refrigerator and sat it on the electrical power cord and it severed it. Fix it or replace it.
  • 706 Answers
I may be able to assist...If you haven't done so already..UNPLUG The cord. Now, depending on where the wire was severed, will impact the degree of difficulty in reinstalling it.
I suggest that you position the fridge so that you can access the place where the cord actually goes into the fridge.
I assume that the cord passes thru a cable feedthru of some kind in the back so you may want to follow that into the fridge.
If the cord was severed outside the fridge you could simply join the 3 wires together as an inline connection ( making sure to keep the supply line, neutral and ground wires bonded to their corresponding ones ... meaning ground wire to ground wire, neutral to neutral and supply line to supply line... line may sometimes be referred to as the 'hot' feed.
If the cord was svered off internal to the fridge, try these steps..
You will probably need to remove an access panel on the back to see where the power cable is routed within the fridge. Once located, you will need to find where that cord was severed when it was pulled out. There should be 3 wires coming into the fridge from the power cord. I assume it came with a standard three prong plug that is compatible with a wall socket. You will have to identify which wire is which on the cord. It helps if you have a continuity meter or ohm meter for this. First, identify which of the 3 wires is bonded to the round terminal of the plug ( that would be your ground wire) That wire should be secured to the fridge frame with a bare screw of some sort. You may be able to trace the cord inside the fridge back to that point or you may be able to reattach the severed wire together using wire nuts to keep the wires joined together and electrically insulated from surrounding surfaces. Remember that it is critical to maintain the same point to point wire configuration as it came with. As a general rule of thumb, a bare copper wire or green insulated wire is typically the ground wire. Depending on the cord type, black insulated wire is normally the supply or HOT feed, and white is typically the neutral line. You may have different color insulation on your wires ( especially if it is a molded cable assembly ) so make sure you verify which wire comes from which terminal on the plug. ( round terminal on plug is ground, the longer of the two ( if it is a polarized plug would be your neutral and the shorter terminal would be the supply line. If unsure, get professional assistance. Hope this helps...
Posted on Aug 06, 2008
How do I remove the door with water dispenser from my Roper Side by Side Refrigerator
Turn water supply to refrigerator off and get a pan or towels to collect what water that will spill when disconnected. On each end of the quick connect coupling is a ring hold the coupling tight with one hand while pressing the ring towards the center of the coupling and then pull the water line out. When replacing the water line trim the part of the water line off where the ring was before or the line may leak once you reattach the water line. Press ring towards the coupling to remove and simply push the existing line after trimming into coupling and pull tight. The grip inside the coupling will lock the line in place. If you have questions please let me know, Thank You Sea Breeze
Nov 17, 2012 | Roper RS22AQXKQ Side by Side Refrigerator
Compressor not runing in a kenmore fridge 25354622402
First the power cord needs to be checked,is it properly connected,next the power cord wire entering the refrigerator side needs to be tested, check with with power unplugged from electric outlet.Its quite possible that run capacitor is faulty and needs replacing. Click this link below for more details:--- --------- This should help.Thanks.Helpmech.
Oct 18, 2011 | Refrigerators
I have a Roper side by side refridge-freezer. We smelled an electrical smell last night. Today the freezer/icemaker thawed out and the refridge also did not cool. I have pulled the back off and checked...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Jan 04, 2011 | Roper Refrigerators
Icemaker does not work
check the water hose. water supply to ice maker
Sep 11, 2007 | Roper RS22AQXKQ Side by Side Refrigerator
Roper RT21AKXKQ Top Freezer Refrigerator Logo
669 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
