Hi i am having problems with my glow worm micron 70 ff. The fan inside is squeaking and keeps stopping ,making the reset and burner on light keep flashing any ideas how to rectify please. If i spin the fan wheel it starts going for about a minute then stops.
SOURCE: coby tf-dvd7100....it only plays half the discs :S
the cable from the laser to the ciruit board is not making contact
Posted on Oct 03, 2007
the dr
  • 447 Answers
SOURCE: kenmore gas dryer 80series model 110.c72852101
90% of all gas dryers lighting intermittently is resolved with new coil packs on the gas valve. The coils are replacable fairly easily and inexpensive.
Posted on Oct 04, 2007
COXY
  • 76 Answers
SOURCE: Diswasher won't start
Try holding the reset button in for about ten seconds.
Posted on Nov 27, 2007
MrBill102
  • 6 Answers
SOURCE: printer problems
All four lights flashing indicated a problem only a service center can repair.
Press the Go button and a new set of indicators will appear.
The yellow toner light only indicates a fuser unit failure.
The yellow drum light only indicates a laser unit failure.
The yellow toner light AND the red paper light indicates a main motor failure.
The red paper light only indicates a PCB failure (Printed Circuit Board).
The only thing you can do at this point is to actually UNPLUG the power cord for 24 hours and then retry or if that fails take it to a service center or better yet go pay the $89 for a new unit.
Hope this helps.
Posted on Dec 26, 2007
bobotfel
  • 236 Answers
SOURCE: flashing lights on system
Maybe the unit is on test run, try to push the test run button of remote control pointing the remote to the unit receiver.6d9792c.jpg
Posted on Jan 07, 2008
Goodman gmh95 furnace wont ignite
try the pressure switch you may be able to jump it out and see if it lights
Oct 01, 2016 | Goodman Heating & Cooling
Kenmore gas dryer 80series model 110.c72852101
if you hear the valve clicking but no gas the valve is bad.when the burner lights theres a probe that senses that it is lit and sends a microvoltage back to the controller to tell its lit.check to make sure all ground wires are grounded to a clean metal surface.
Oct 03, 2007 | Kenmore 74602 Gas Dryer
50E47-70 unit intermittent failure. HSI glows, gas valve clicks, but burner does not light. Cycles several times but does not light then flue fan continues to run until furnace shut off. Sometimes...
Hello, sometimes even though the igniter is glowing it can be weak and not able to ignite the gas. Also, since the gas valve is clicking that means that it is receiving 24 volts but it is also possible that gas valve is sticking and not allowing gas to flow to tne buners everytime.
Sep 06, 2011 | Heating & Cooling
I have a Rheem Furance that has turned off. Just a few hours ago the main fan turned off. The Furnace doesnm't light even the draft fan does turn on and then the main fan blower motor turns on. I can hear...
You will need to reset the furnace by turning the power off to it. Then as the furnace tries to light, watch the LED for blinking. Hopefully it will give a code other than 1. Try checking the air filter for blockage, make sure all hoses are free of moisture and any drains are not blocked. Check the air intake and exhaust pipe for sags where water could block it.
The sequence of operation is this:
Thermostat calls for heat, the LED may blink telling you it registers the call. The inducer (exhaust) blower starts closing contacts in the pressure switch (small disc shaped thing), the igniter glows orange (seen thru a small window high up on furnace front), gas valve opens allowing main burner to light, flame travels to all other burners, flame rod senses flame within a few seconds and keeps gas on. Room air blower starts within 90 seconds.
Any deviation or delay in this sequence and it goes into lock-out.
Jan 22, 2011 | Heating & Cooling
Service manual for glow worm boiler micron soff
Can you give a model number and more info? I think you mean a micron 60ff in which case it is here: http://www.glow-worm.co.uk/stepone/data/downloads_sd/8d/00/00/micron-60ff.pdf
Jan 02, 2011 | Heating & Cooling
I hope that I can get this problem resolved. Can there be a thread started to help me through this? I will try to keep this as short as possible, I have a Ducane Mod. CMPB050C3A Nat. gas furnace. The...
say that you have the glow bar (Hot surface igniter) working
if the flame starts make sure you don't trash on the orifice of the burner, you can try to use a piece of wire or someting small to pick on the orifice of the burner, also make sure is not rust bewteen the burners gap where the flame spread to all the burners because if the flame sensor don't feel flame don't stay light up
hopes this help
Oct 09, 2009 | Heating & Cooling
No ignition and E04 Code
The HSI (ignitor) has 2 wires, its like a cigeratte lighter, power is applied and it heats then glows red, the single wire you mention is the flame sensor, used by the control board (igntion module) to ensure the burner has lit or it shuts the power to the gas valve off but keeps the fan operating for a period of 1 hour till it resets.
It sounds like your ignitor is defective, it happens often, depending on your location, you may be able to purchase one, but I would advise having a service tech do it.
The manual for troubleshooting and repair can be found at this link:
http://www.staritepool.com/pdfs/MiniMaxNTServiceManual.pdf
Aug 14, 2009 | Pentair MINIMAX NT TSI IGNITER
Ff and fan noise
fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
Thanks.
Jun 18, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Display screen says "Er ff"
LG's bottom mounts have had problems with air leaks in freezer making a iceball right under the evaperator fan actually coming close enough to the fan blades to slow them down or stop them all together also causeing the FFerror meaning the control board is not detecting the normal RPM's you should to keep it cool enough. Suggestion take the back panel off and remove any ice carefully if this be the problem. Make sure all doors are closeing tightly and gaskets make a air tight close.
Jan 20, 2008 | LG LFX25960ST Stainless Steel French Door...
Heating & Cooling Logo
119 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
