Question about Husqvarna Yard Tractor
My name is Lee Shrake, i got a husqvarna model Lth1538. its been great. but i was mowing and stopped to move some sticks and now it wont move. rear end just growls. never had problem before. please any help would be great. thank you
    Brigadier General:
  • 3,911 Answers
If it has a hydrostatic transmission, then it is going bad.
Posted on Apr 06, 2011
My husqvarna wont go forward or reverse good I keep moving the 2 steering arms and it will move but not like it suppose to could it be the v belts and where are they located at
If the unit stopped at once, it is probably the belts. Check under the mower, they route over the wheel pump motors at the rear of the mower. Looking underneath from the rear you will be able to see the belt(s)
May 13, 2017 | Husqvarna Garden
Is there any way to bypass the switch that engages the blades on my Husqvarna RZ4219 zero turn mower so that it will start?
get a test light, this will make troubleshooting alot easier. check seat switch,stick,neutral,guard and the power in and out of the key. 6 12V Circuit Tester with 5 ft Lead
Sep 04, 2015 | Husqvarna RZ4219 42" 19.5HP Zero Turn Lawn...
WONT GO FOWARD OR REVERSE
Not sure what all you checked but did you look at your drive belt? If it slipped of the pulley everything will still work just fine but it want move.
Aug 09, 2015 | Husqvarna Garden
While mowing my lawn the Husqvarna YTH1542xp with a twin Kawasaki engine suddenly stopped. Will not start again, had blown 20 amp fuse, replaced fuse and starter engages, but engine won't turn over....
Maybe it threw a rod or piston.. maybe the piston seized up. Can you get the blade to rotate at all? Use a stick to try that, not your shoe.
Dec 03, 2017 | Husqvarna Garden
My 42" Husqvarna (model #917.279240
Remove the center dust caps from the rear axles, start the tractor up and put it in gear and observe the axles, if one of them is spinning freely inside the wheel, you have lost the 1/4" square key that pins the wheel to the axle. Replace the key and you can go back to mowing. Hope this helped Tim
May 15, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Mowing great but l moved off seat while cutting and now blades wont turn on, something to do with safety switch on seat but l dont know how to fix problem
your problyright to check safety switch unplug it and take a peace of wire about 4 inches skin each end stick into each side of plug [ just jump the plug
Oct 11, 2009 | Garden
Mtd model series 790 mower wont move, belts are fine and transmission wont go in nuetral
mtd 1993 riding mower model 828 I was mowing then tractor stopped and wont go forward or backward It runs fine, and blades
seem fine. Drive belt looks fine.
Sep 17, 2009 | Mtd Garden
HYDRASTATIC TRANSMISSION DOESN'T MOVE
Far as I know the warranties are not transferable. Some hydrastatic transmission fluid can be checked by removing the battery and underneath there is a place to put the fluid and to check it. But not all models or makes gives you this option.
Jun 22, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Yard Tractor Logo
466 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
