I have a baseboard heater that has a control knob on the heater, the brand is stelpro. I was moving furniture around the living room and ended up snapping off the control knob on the heater. Is there any way to fix this, or do I have to get a new heater?
    Sergeant:
    Champion:
  • 277 Answers
Use qbond to sick it back on its a fast adhesive
Posted on Apr 05, 2011
" 1500-w wall convector" from uberhaus compared to "1500-w electronic converter" Stelpro
One of the main differences is the stelpro is 110 volts and the uberhaus is 240.
Dec 02, 2013 | Fahrenheat Electric Convector Baseboard...
I live in an old building and today there is a strong gas smell coming from my base board heater in the living room. I'm not sure if it is electric or gas. There is water like knob inside of it but there...
The heater you're concerned about is an Electric Heater. So, I'm not sure why you're smelling gas. Is it a rotten egg smell or more of a plastic burning smell?
Feb 25, 2011 | Fahrenheat LFP6152 Halogen Baseboard...
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
I have a baseboard heater in my apartment (small dining area) that has a dial that I can control the heat..the knob has #1-10...what is a good number to set it to and do I keep it on all the time. Thanks...
Hi!
The number you keep it on is whatever temperature that is comfortable to you. The settings on the dial are graduated from #1(lowest-coolest) to #10(warmest). If you want to keep the room temperature somewhat even you need to play around with the settings( one number at a time) until you find what is comfortable to you. Hope I was of help to you.
Dec 02, 2009 | Fahrenheat FBE15002 Baseboard Heater
Broken control knob
go to a used appliance store, they have tons of those things!
Jul 24, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Baseboard heater running all the time
since they have indivial twist knobs that regulat temp, the thermostat is bad on one in hall either replace knob which should have thermostat built in or whole unit
May 03, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
Electric baseboard heat not getting hot
Is your fuse box and main power source large enough to handle the full load if all are turned on at the same time? Are you uses two pole breakers? you might only be feeding with 110 volt. This would prevent them from getting very hot.
Jan 03, 2009 | Heating & Cooling
Electric baseboard heaters
measure the room, then multiply the length by the width to get the square feet you want to heat. multiply this by 10 and that is the watts you need to heat the room assuming you are using standard 220/240v baseboards.
Dec 25, 2008 | Marley Electric Hydronic Baseboard Heater,...
There is a Singer Baseboard Heater in one of my rooms. We bumped it while moving furniture today and it turned on. We have tried moving the dial both left and right and can't get it to turn off. Any...
I was able to determine and turn off the breaker. I am having a heating and air conditioning company remove the heater altogether. Thank you for checking back with me.
Jul 12, 2008 | Heating & Cooling
Heating & Cooling Logo
179 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
