Our televsion started making a noise like a roaring/frinding noise and then hte pic whent white and it had small black dots all over it. The noise is very loud. Please tell me what is wrong with it.
  • 325 Answers
Your capacitor in your power supply has blown and created damage to the mainboard OR T-con board. When you open the tv attempt a powersupply repair with replacing the capacitors with the same uF value and a HIGHER voltage value. Once that repair is made you will need to test the tv to see if picture/sound is restored. If not, you will need to replace your T-con board for sure and possibly your mainboard.
Hope this helps! let me know if you need anything else.
Posted on Apr 05, 2011
A/c light is blinking and makes a roaring noise
the blinking indicates a/c didnt engage / not working the roar can be the clutch went bad or bearings went ==which more than likely will need a replacement
Sep 01, 2016 | 2002 Toyota Sequoia
Ecently a small dull black dot has started appearing on my canon power shot A630's lcd screen but when I review the pics taken prior to when I noticed this problem, no dot appears.
1) this is indicative the lcd camera has been faulty.
2) you must replace it.
3) contact your company supplier, and get the parts, you can do it yourself, only need small screwdrivers and common sense.
God bless you
Sep 17, 2012 | Canon PowerShot A630 Digital Camera
How do you clean the dust out of the projector, there are particles that look like small white stars on the black areas and black stars on the white areas. Is this dust?
If you focus the image on a screen up close to the projector and notice small rectangular black and white spots, then you have pixel failures.
Jul 11, 2011 | Optoma TX542 Projector
My kyocera color copier has blue dots going across the page when I make color copies.
I beleive you listed your question under the wrong model machine. The CS-4035 is a black and white copier and should not be making bluse dots. Verify the model number please.
Feb 03, 2011 | Kyocera CS-4035 Copier
We have a Sony Bravia KDL-40V3000 flat screen television. About 6 months ago, the screen started displaying white, green and black vertical lines and dots. This continued for a few weeks and then the...
It's a connection inside the TV that's faulty. It could be as simple as reseating the ribbon cables that connect the control board to the glass display. Or it could be that the fault is on the board and needs to be replaced. The fact that the problem comes and goes should tell you it's fixable.
Apr 28, 2017 | Sony BRAVIA KDL-40V3000 Television
My DLP617W is black and white today and tried everything I know, does not work. Any suggestions ? Thank you.
i'm probably sure that is the dmd let me know a couple of things.
TV make's were noises? the white spots comes and go?
it look like this?
Dec 28, 2009 | Samsung HLN617W 61" Rear Projection HDTV
White dots on screen
your dmd chip is defect this a good job you must tack emgine apart calculate atleast 200 dollars
Dec 06, 2008 | Samsung DLP HL-P5663W 56" TV
Black streaks, smudges and dots from drum
take a rag and wipe around front door boot first does any thing come off on rag if this ckd ok does it keep a roaring noise when spinning? if so suspect rear bearing or corrision on spider this is tub support behind basket..ask for estimate before repair as this could result in major expense to repair good luck
May 28, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
