Question about Sanyo Xacti VPC-WH1 High Definition Camcorder
My lens got condensation inside, cant seem to get rid of it. what can I do?
  • Anonymous Apr 05, 2011
    I tried rubbing cloth against the lens to produce heat, dry it out... it actually worked very well.
There is a circle within the lens and when I take pictrues, there is a white shadow circle in the pictures. How do I prevent this from happening?
If the pictures taken are slightly misty, using a soft lens tissue (or spectacle cleaning cloth) wipe the lens delicately in one direction until the 'circle' has gone. Don't 'huff' on the lens as this will cause condensation INSIDE the lens.
If this fails to fix the problem, it may well be condensation build up inside the lens. If you have a sachet of silicone crystals (like the wee bags that come with a new pair of shoes), place the camera inside an airtight container with the sachet. Leave for minimum of 12hrs. This should absorbs any if not ALL of the condensation inside the camera.
Nov 25, 2013 | Kodak EasyShare M583 Digital Camera
Halo around main subject
Check for dirt on the front element of the lens. I am always amazed that almost every point and shoot digital I see has a filthy lens.
This can also be caused by condensation inside the lens or on the rear element
Feb 03, 2013 | Canon PowerShot SD550 / IXUS 750 Digital...
Blury photos & blury screen (fe 270)
Can be cause from many things.. most common would be dirty and/or scratched lens. Another cause could be condensation inside the device itself. Look into the lens and see if it seems misty or coudy.. at an angle also to see if the should be smooth lens is matte (rough). If it looks like it's misty or steamy behind the lens then that means you need to let it 'dry out' in a warm dry place.. or.. take it to a photo shop to have it maintained.
Mar 25, 2011 | Olympus FE-270 Digital Camera
My head lights are very fogged i bought the restoration kit but cant figure out how to take off the cover to apply the soulution
Those restoration kits are only for the outside of the lenses. They oxidize and you use that kit to remove oxidation. If the haze is on the inside you need to replace the entire housing. They're sealed from the factory. Some people have tried to disassemble and clean insides but the success rate is very low.
Feb 18, 2011 | 2000 Mercury Cougar
Ps3 disk read error
This problem has something to do with your PS3's lens. It may have gone bad too. This happened to me too and I brought my PS3 to sony. The culprit was bad lens.
I hope this helps. Have a nice day.
- HotRatchet
Dec 14, 2009 | Sony Playstation 3 (PS3) Console
Appears watermarks on inside lens - hence on to pics
I'm guessing it could be condensation, try gently warming the lense with a hairdryer.
Apr 30, 2009 | Cameras
InFocus LP70+ condensation/smudge INSIDE of lense
there is, but it is a pain. you need to remove the top, the cables off of the main board, the 3 screws on the main board, the spacers on the dvi connector, the rear screen (by it's screw), the fan underneath the board, the colorwheel guard, the 3 screws holding in the optical engine, then the optical engine. now you can remove the 3 screws for the lens and remove the lens. now if you can remember the spacing on the focus/zoom rings, remove the screws and unscrew the lens barrel and clean it. now put it back together. it might be easier to find another used lp70+ and swap out the parts.
Feb 22, 2009 | InFocus LP70+ Multimedia Projector
How do I remove condensation from inside my camcorder lens?
place on oven @ 320F for 10 mins. flip over and add bbq sauce.. should be done. <JUST KIDDING>
leave tape out, put on sun for couple hrs.
Oct 10, 2008 | Panasonic NV-GS200 Mini DV Digital...
BLURRY OR FUZZY LENS
Perhaps you have had the camera in a very humid environment and now there is condensation inside? Perhaps try putting it somewhere warm and dry (not hot) for several days. Switch it on and off (and zoom in and out a bit) a few times during this period to change the air inside the lens. This will help expel the moisture.
I assume that it isn't just finger marks on the front of the lense? If it is, you can use a cleaning cloth (for eye glasses or from a camera shop) to clean it.
Jul 20, 2008 | Samsung Digimax A402 Digital Camera
Sanyo Xacti VPC-WH1 High Definition Camcorder Logo
49 people viewed this question
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Mark Magill
Mark Magill
Nicola Conroy
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
