Question about LG Dishwashers
I have an error code OE, which is related to the pump. The pump still sounds like it is running, but water is not going out. I think it is a clog. But the hose looks OK under the sink. Do I need to take apart the inside to see where the hose is hooked to the machine? Do you have a schematic to show me how? Thanks
  • 822 Answers
Take the back off....follow outlet hose back to the pump..........
.take pump clip off and unblock it,........
cheers
Posted on Apr 05, 2011
Testimonial: "Thanks so much. I will try it."
My washer has OE problem code, it won't pump out the water.
Hello!
The error OE of the washing machine means:
1) Somewhere in the drain system (filter, hoses) there is a serious clog.
or
2) Strong clogging of the sewage system
3) The drain pump broke, or
4) The water level sensor is faulty, or
5) The electric controller is faulty.
May 13, 2017 | Washing Machines
-I have a Daewoo washing machine DW F1251S with OE error code. What doesthis mean?
Possible this is relative of a poor drain time which means a clogged draining pump and system. So it si best to remove and clean the drain pump/filter and reset.
check if the machine drain hose is connected to a outlet which is not clogged when the water is flushed out . Also the washing machine must be slightly tilted to drain to the pump to reduce the drain timing.
Finally check if the machine was overloaded to produce a strain on the motor so as to give an error. If so shut down remove plug remove load , check if the agitator is jammed and reset.
Nov 21, 2011 | Washing Machines
I have the error code OE showing up, and the water is not draining from the washer. What should I do?
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages. Clean out the trap from the bottom, something is jamming the drain motor.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Jun 22, 2011 | LG WM-2277HW Front Load Washer
Getting a "oe" error how
See
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Check the drain hose for blockage. and see if the water filters is clogged. Specific instructions will vary based on your specific LG model. Most LG frontloaders have an access panel on the front for the water filter.
Apr 21, 2011 | LG Washing Machines
Bell is ringing, 'OE' flashes on display; washer continues running
The error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
CLICK HERE
Thanks for using FixYa
Dec 28, 2010 | Washing Machines
Im receiving an OE error code on my LG Dishwasher Model LDF7811st. The machine runs for a little bit and then it dings a few times with the "OE" code and stops running. HELP please
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 21, 2010 | LG 24 in. LDF 7811 Stainless Steel...
I have the LG Tromm 27'' Front Loader model WM2277HW
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
Getting the OE error message on LG Tromm
Hello! I have an LG frontload washer and it was going fine until a few days ago. It had 14 min left of a cycle and displayed the error message OE. Checked my owners manual and it said that the drain pipe...
Sep 25, 2009 | LG WM-2277HW Front Load Washer
Error Code OE and Door will not unlock
error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly.try running the spin cycle alone till the water empties completely.If the problem still continues it means that the pump is clogged where you cant reach, since you've tested with the drain hose.
Dec 16, 2008 | Washing Machines
Dishwashers Logo
385 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
