Question about Mach Speed Computers & Internet
Motherboard specs I am having ram issues and would like to no a few things. i have a mach speed msa2-6100v socket am2 venom motherbaord with amd nvida chipset. First i cannot get certain ram to work right i have working kingston ram 6400. however when i try kingmax sdram 5300 it does not work...? I am trying to upgrade ram and am wondering if there is suggestions that will work. Second i am also upgrading my video card will i have problems with a 1 gig nvida video card. i have read the specs of the motherboard "with 250MB max shared video memory" <--- is this the onboard video? or all video in general. any help with this i would appriciate thanks.
  • dwman113 Aug 06, 2008
    basically my question is
    1. (2x1gb) ddr2-800 pc-6400 will work? "what is cl5 stand for??"
    2. any PCIe 1.0 video card will work on this board? no matter how much ram or if it is newer with sli or something? i am planning on buying Sparkle GeForce 8500 GT Video Card and want to make sure its compatible
    correct?
    President:
  • 2,351 Answers
Hi dwman113,
Yes your Mach Speed MB will support 2x1 GB, Dual Channel Mode DDR2-800MHz, PC6400 memory modules. (Manual states the memory dimms should be paired).
Also known as matched memory.
Max Shared Video Memory is 256MB, refers only to the integrated built in video card.
Click this link to help you understand what CL stands for; http://www.hardwaresecrets.com/article/26/3
Small example. CL3 runs faster than CL5.
You can run any PCI-Express 16x graphics card & it can be rev 2.0. Graphics cards are backwards compatible which means it will also run at v1.0. You should not buy a SLI card because you only have 1 PCI-E x16 slot. To run SLI, (Hooking up 2 PCI-E x16 cards together viva a small SLI connector) your motherboard would need two PCI-E x16 slots & the board must support SLI mode & your's does not. Here is the main web site link for your Mach Speed MSA2-6100V MB.
http://www.machspeed.com/specs/viper/MSA2-6100V.html
If you have any more issues or questions just post it & we'll go from there.
Good luck dwman113!
Mike
Posted on Sep 16, 2008
SOURCE:
I cannot play my game
You have to upgrade your motherboard and add additional ram and graphics card.
Now you will be able to play the latest games.
Dec 04, 2010 | ASUS M2V-MX SE AMD AM2 Socket AM2 2000 MHz...
Can i change my processor? AMD LE-1150 to dualcore or core2duo?
If your using AMD LE-1150 you cant use a dualcore nor a core2duo because the socket of your motherboard is for AMD microprocessor only you can upgrade or change your procs to any AMD AM2 dual core model make sure you check the specs of your motherboard for supported CPU list. you can find that in their website
Apr 27, 2010 | AMD Sempron LE-1150 2.0GHz Processor -...
I am trying to replace my motherboard with the exact same one but can't find what I need to order it. I've done searches but keep finding different answers.
From my searching I find that it is a Nvidia 520LE.
With much tact and diplomacy, I would like to 'talk' to you straight up.
That motherboard is junk.
The motherboard is just an ordinary, ATX form factor motherboard. The most common used form factor size, used in personal computers.
Uses the Nvidia nForce 4 chipset.
By the time you buy an exact replacement motherboard, you will have spent the same, or more, than you could spend for a much better motherboard. (That will fit! Only the I/O shield at the back of the computer, may not line up with the motherboard below. The motherboard does come with an I/O shield anyway)
I found from my recent search also this motherboard,
1.http://www.newegg.com/Product/Product.aspx?Item=N82E16813135075&nm_mc=OTC-pr1c3grabb3r&cm_mmc=OTC-pr1c3grabb3r-_-Motherboards+-+AMD-_-ECS+%28EliteGroup%29-_-13135075
$70 US.
Instead of the Socket 939 processor socket, or AM2 processor socket, you have now, you will have an AM2+ processor socket.
If your processor you have now, is an AM2 processor socket model, it will work on this motherboard.
Your ram memory won't work. You have DDR ram memory. This motherboard uses DDR2 at 800MHz. (Or also can use DDR2 at 1066MHz)
This = a PLUS!
You can buy 2GB's of DDR2 ram memory that operates at 800MegaHertz, for $30 at Tigerdirect. (Patriot Dual Channel-PC6400. It's two ->1GB sticks of dual channel capable ram)
Uses the AMD (Nvidia based) 780G Northbridge chip, and the AMD SB700 Southbridge chip.
Here are the specifications of this motherboard straight from ECS,
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=866&CategoryID=1&DetailName=Specification&MenuID=1&LanID=0
Aug 19, 2009 | Acer Aspire E360 PC Desktop
What is venom?
hi im josh in cebu phils . Venom literally means a poisonous substance in animals and plants but in PC it is only a code brand which means tough strong or powerful The V2DP is our newest addition to the Venom motherboard line. Mach Speed has taken one of our best selling motherboard, the V4MDMP, and made a low cost solution with a 333 Front Side BUS and 4x AGP slot producing an awesome all-in-one, low cost motherboard. The Venom V2DP is a very versatile motherboard on todays market. This feature enriched motherboard supports AMDs Athlon XP 333FSB processors, DDR 333 memory, and has a 4x AGP slot for High Performance systems or take advantage of the Integrated Video, Sound, and 10/100 LAN for a cost effective solution. The integrated UniCrome 64mg Video is ready for crystal clear DVD playback and high-resolution gaming. On Board 3D 6 Channel Sound will take full advantage of your high fidelity sound system and onboard 10/100 LAN is ready for broadband internet or a high speed network thats all hope i helped you.
Feb 26, 2009 | Mach Speed VENOM V2DP Motherboard
Hi i have a ram issue
specs for motherboard mach speed venom
Memory type ddr2 sdram
Memory slots 2 X 240 pin slots
Supported ram 800mhz 533mhz 400mhz 667mhz
I dont know if this will assist you in sorting problem out
Aug 02, 2008 | Mach Speed VENOM MSA2-6100V Motherboard
Processor upgrade
Need to look at the motherboard specs along with the processor "Socket". It will usually be a 754 or 939 depending on what your motherboard says. I wouldn't try too fast and set yourself up for disappointment. I would upgrade the RAM before the processor.
Mar 22, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
197 people viewed this question
Top Mach Speed Computers & Internet Experts
Ekse
Thomas F. Schneider
Marvin
Marvin
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
