Question about Canon imageCLASS MF6590 Copier
I have a ImageClass MF 6590 with a message of 'PAPER JAM" but is not a paper in the machine, how can I reset the control panel?
  • 537 Answers
SOURCE: Cannot find paper jam ...
We have a D780, which is probably very similar to your unit. Have you removed your toner cartridge and inspected to see if any paper is in the paper path? 95% of the time that is where the paper jam is.
Posted on Oct 21, 2008
solofixya
  • 34 Answers
SOURCE: Canon PC 1060 has a paper jam that we can't get to
It sounds like the paper jam is in the fixing assembly, and you can not access it unless you take it to a service center for canon products.
Posted on Nov 10, 2008
fer_nan_14
  • 76 Answers
SOURCE: paper jam in the fuser unit.
hi
first you must remove the side panel on fixing side and move the scanner unit to reveal a two hole at the top of the machine,total of 3 screw for fixing unit,and one of that screw in front side of fixing unit you must use small philips screw,and take care to remove the wire
Posted on Dec 13, 2008
  • 135 Answers
SOURCE: Paper Jam Error but no paper is jammed
depnding on which way you removed original jam you could have left a very small peice behind at a sensor arm, inspect very carfully at and before where the jam was
Posted on Apr 19, 2009
SOURCE: Canon Imageclass D320 supply rec. paper malfunction
My problem was that I was trying to print from a PDF file. I found out that the file was legal size and that the setting for the printer to "choose paper source by PDF size" was checked. I unchecked it so that it would print on letter size paper. Hope this helps
Posted on May 06, 2009
Canon printer MF 8080 cw will not reset after a paper jam
Hello, If the printer will not reset then you still have a piece of paper stuck somewhere in the paper path. Did you power the printer down and back up? Here is manual.
Canon imageCLASS MF4150 Manual
Sep 30, 2014 | Canon imageCLASS MF4150 All-In-One Laser...
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
I had a major paper jam at my printer (Canon, Super G3, imageClass MF 4150). I removed all the paper which was not easy. The printer is not working and switches to following messages: Paper Jam, Lift panel...
  1. Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
  2. Step 2 Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
  3. Step 3 Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
  4. Step 4 Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
  5. Step 5 Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
  6. Step 6 Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
  7. Step 7 Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
  8. Step 8 Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
Jan 26, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Printer canon mf 5750 thankyou verymuch
please chack your paper feed sensor i guss it was broken
Aug 04, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Can't find paper causing Jam
Please go to this link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=13099#SupportDetailAct
and type in there that you are looking for paper jam issue it will give you number of steps follow then and that will resolve the issue.
Aug 09, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Am have Problem with Canon MF5700.
hey, I keep getting a paper jam message but there is no paper jam. Opening the cover does not reset, nor unplugging the machine. Bob
Jul 02, 2008 | Canon imageCLASS MF5730 All-In-One Laser...
MF-8170C REC. PAPER JAM and Open Cover
Get a thick piece of paper and feed it in to the printer following the paper path the best you can until you get the piece of paper you can't see out of it.
Oct 16, 2007 | Canon imageCLASS MF8170C All-In-One Laser...
Canon imageCLASS MF6590 Copier Logo
44 people viewed this question
old marine
old marine
